I would like to be able to have i.mx8m mini evk access wifi router and act as hotspot using hostapd simultaneously.
I am using ubuntu-18.04.2.
Here are the steps I took:
auth_algs=1
channel=6
hw_mode=g
ieee80211n=1
ignore_broadcast_ssid=0
interface=wlan0
wpa=2
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
driver=nl80211
ssid=<name>
wpa_passphrase=<passphrase>
I then tested WAP by doing "sudo /usr/sbin/hostapd /etc/hostapd.conf &”
Each of these work individually but not together (obviously). I believe I need to use dnsmasq and iptables to masquerade virtual interface, but this is quickly getting over my head. Can someone assist?
Jeff
Hi Jeff
one try with latest murata linux wifi documentation (sect.7.1.8 Soft AP or Wi-Fi Hot Spot Testing)
from wireless.murata.com/products/rf-modules-1/wi-fi-bluetooth-for-nxp-i-mx.html
Murata Quick Start Guide (Linux) 6.0
Thank you for the link.
Referencing the command from the documentation you sent: udhcpd -S -I 192.168.1.1 /etc/udhcpd.conf
there is no /etc/udhcpd.conf on my system.
Also, there does not seem to be a -I option for udhcpd.
Any advice?
for additional help may be recommended to apply to tech support of vendor of that wifi module
https://wireless.murata.com/contact.html
Thx Igor. How did you know what vendor supplies the wifi?
Oops. Nevermind. I see it in the spreadsheet of the BOM for the schematic. Thx for the advice!
Jeff
