Hello everyone,
RM show eCSPI one can be of low speed What mean?
SPI4 only low speed?I can't find the exact instructions in the manual
Solved! Go to Solution.
You may refer to the datasheet https://www.nxp.com.cn/docs/en/data-sheet/IMX6ULLCEC.pdf
Full-duplex enhanced Synchronous Serial Interface, with data rate up to 52 Mbit/s. It is configurable to support Master/Slave modes, four chip selects to support multiple peripherals.
Why is the reference manual different from the datasheet?
I think it is a typo in RM
