I use LAN8720A in my i.mx6Q board,I want to use u-boot2013.04, how can I do ?
Solved! Go to Solution.
There are some bugs in the "fec_mxc.c ", you can download "u-boot-2013.10-rc1" version get the difference between the u-boot-2013.04 version, then you can find the bugs.
How are you setting the MAC Address of the board?
Yes, I set it use "set ethaddr 00:00:01:02:03:04" command.
