Hi all,
I am currently encounter another issue on the NAND integration for i.mx6SOLO.
I am using uboot version 2009.08.
NAND used is MT29F32G08CBADAWP, 4GByte, 2MB erase size, 8kByte page size.
I keep getting [read data]: DMA error message if i tried to read the NAND flash from uboot.
This happens also when the uboot trying to find the bad blocks while accessing the bad block table block.
I had done some experiment on the read_data function in gpmi_nfc_hal.c by limitting the DMA read size manually. I found out that if the size is less than 4095 bytes, the error will not be out.
I had change the NAND_MAX_PAGESIZE to 8192.
Is this due to uboot unable to handle big size (8kByte) DMA transfer? Is there any patch that can solve this issue?
zc
