i.mx6 ltib elftosb build
frankmiller
Greeting,
I'm trying run ltib for the first time from the i.MX6 source tarball.  I'm using Ubuntu 12.10  Here's the error I get after awhile:
Executing(%build): /bin/sh -e /home/fwmiller/Freescale/ltib/tmp/rpm-tmp.25768
+ umask 022
+ cd /opt/freescale/ltib/usr/src/rpm/BUILD
+ cd elftosb-12.09.01
+ make
make -C bld/linux -f /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/makefile.rules SRC_DIR=/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01 all;
make[1]: Entering directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/bld/linux'
gcc -g -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/elftosb2 -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/keygen -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/sbtool -I/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common -DLinux -c /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/AESKey.cpp
In file included from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/AESKey.h:10:0,
                 from /opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/AESKey.cpp:8:
/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/common/stdafx.h:30:36: fatal error: /usr/include/sys/types.h: No such file or directory
compilation terminated.
make[1]: *** [AESKey.o] Error 1
make[1]: Leaving directory `/opt/freescale/ltib/usr/src/rpm/BUILD/elftosb-12.09.01/bld/linux'
make: *** [all] Error 2
error: Bad exit status from /home/fwmiller/Freescale/ltib/tmp/rpm-tmp.25768 (%build)
RPM build errors:
Build time for elftosb: 0 seconds
Failed building elftosb
Died at ./ltib line 1392.
traceback:
main::build_host_rpms:1392
  main::host_checks:1447
   main:554
Started: Fri Mar  1 09:43:46 2013
Ended:   Fri Mar  1 09:57:04 2013
Elapsed: 798 seconds
These packages failed to build:
elftosb
Build Failed
Any thoughts?
FM
Labels (4)
frankmiller
K, so I discovered that 12.10 has no usr/include/sys directory.  I did this in /usr/include:
sudo ln -s i386-linux-gnu/sys sys
and the build continued to completion!
Thanks to me I guess :smileywink:
FM
frankmiller
FM
