i.mx6 MMDC Core Special Command Register
677件の閲覧回数
zc_tee
Hi all,
I am currently fine-tuning my DDR performance, and i come across this MMDC_MDSCR (1Ch offset) register which is used to issue special commands manually towards the external DDR device.
However, the information in the reference manual is not much, and it certainly did not explains the types of special command, and how to use it.
May i know where can i find the information about this Core Special Command? Any explanation on how to set the register, what is the reason and effect on setting the register would be helpful.
Thank you.
Tee
ラベル(2)
タグ(3)
494件の閲覧回数
igorpadykov
Hi Tee
this is used for sending special commands to ddr chip, like configuring Mode Registers.
Examples can be found in scripts for ddr tester tool
https://community.freescale.com/docs/DOC-105652
ddr_stress_tester  folder ../script/ , for example attached MX6SL_EVK_LPDDR2_512MB_32bit_v0.9.inc:
// LPDDR2 Mode Register Writes
setmem /32    0x021b001c =0x82018030    // MRW: BA=0 CS=0 MR_ADDR=1  MR_OP=see Register Configuration
setmem /32    0x021b001c =0x04028030    // MRW: BA=0 CS=0 MR_ADDR=2  MR_OP=see Register Configuration
