i.mx6 HDMI_HPD pin not detected
4,729 次查看
zc_tee
Hi all,
Currently i facing problem where i cannot get the HPD interrupt.
I checked the hardware signal, when plugged in, the HPD pin is HI, and when plugged out, the HPD pin is LO.
However, kernel does not goes in to irq routine mxc_hdmi_hotplug, and also not going in to hotplug_worker at all.
Any idea why is this happening? i am using kernel BSP 3.0.101.
ZC
标签 (3)
标记 (2)
3,404 次查看
zc_tee
Hi Igor,
Found the problem. The board does not connect the HDMI_VP and HDMI_VPH to the correct voltage. The HDMI core does not power up at all.
Thanks and sorry for the mistake.
ZC
7 回复数
3,404 次查看
HI ZC
one can look at links discussing about HDMI_HPD detection
https://community.freescale.com/thread/327503
https://community.freescale.com/thread/326283
3,404 次查看
zc_tee
Hi Igor,
The links above describe the basic functional of the HPD pin, as well as another problem from an user who gets the interrupt infinitely.
However, in my case, i do not get the interrupt at all. Therefore I think my problem is different from him.
I had tried to connected directly the HDMI connector's HPD pin and i.mx6's HDMI_HPD pin, but still no luck. HPD interrupt still not detected by the kernel.
I am using a Philips Monitor. Monitor is confirmed to be working as i can connect it to my PC and it shows.
ZC
3,404 次查看
HI ZC
could you check HDMI_PHY_STAT0 bit HPD ?
3,405 次查看
zc_tee
Hi Igor,
ZC
3,404 次查看
zc_tee
Hi Igor,
HDMI_PHY_STAT0 and HDMI_IH_PHY_STAT0 both read as 0x00 regardless HDMI cable is plugged in or out.
ZC
3,404 次查看
HI ZC
what board are you using, could you check on Sabre board ?
3,404 次查看
zc_tee
Hi Igor,
I am using our custom board. I will check on sabre board when i got some time later on. Now proceed with other task already.
