i.mx53 qsb android can, i2c, spi access
RamonRivera
Is it possible to control the can, i2c, spi from an android application?  I've been able to use the debug serial port to send information with some success, but I cannot figure out of a way to do it via the can, i2c or spi.  Is this something that can only be done from a linux instead of android?
Any advice is greatly appreciated.
RamonRivera
Thanks Tom, I appreciate your input.
-Ramon
TomMinnich_ng
Ramon:
 I do not have what you are looking for ( i am really really new to Android), I hope someone in the community does.
Best Regards
 Tom M.
RamonRivera
I've seen that alternative.  Using the NDK to develop C++ libraries.  I do not have that much experience doing it that way but I'm hoping that I could get an api that would cut in developing time.  Do you have any example of an ndk jni library that uses i2c, spi, can?
TomMinnich_ng
Ramon:
 I am very new to android development, so you may want to check my advice. The Native toolset creates applications written in C++ that are compiled and not Java applications. This opens many brute force possibilities.
If someone knows better ways, that keeps things in a Java programming environment I would certainly like to hear about them.
Best Regards
Tom M.
