i.mx53 power and benchmarks
erwinw
For some reason, I am unable to find a datasheet on the i.mx53 products to look at power, but regardless, I would be interested in any power numbers or benchmarks available against similar A8 architectures and how the i.mx53 stacks up. Can you point me to this data?
Also would be interested with performance benchmarks available on the i.mx53 at this time.
Thank you,
KarlLu
There are application notes for i.Mx53 power consumption in typical use cases. You can search AN4270 at freescale.com
http://cache.freescale.com/files/32bit/doc/app_note/AN4270.pdf?fsrch=1&sr=3
