i.mx28 and large kernel with initramfs = oom killer
1,035 次查看
oskiercz
Hi everyone,
I'm trying to use kernel combined with initramfs which is 8MB big (uncompressed ~25MB), but when kernel is booting some oom-killer actions are taken (output attached). I have 128MB of RAM so size of memory is not an issue. I suspect that problem is that uncompressed initramfs + kernel overlaps some memory region which should not be touched. Is the size of memory for uncompressed kernel along with initramfs limited somehow? Could anybody help me? I can add that when kernel and initramfs image are separated then system works fine.
Original Attachment has been moved to: initramfs.fail.zip
标签 (2)
标记 (5)
614 次查看
igorpadykov
Hi oskiercz
for initramfs configuring please look link below
https://community.freescale.com/thread/305045
chip
614 次查看
oskiercz
Hi chipexpert,
I forgot to add that I have to use u-boot as a bootloader, which as far as I understand, doesn't allow me to use imx28_(ivt_)linux.sb file (because it's booted itself, without any external bootloader), so second method from link you provided is not for me (third also because it's about separated images).
What I found out, that there is a size limit for kernel image (if initramfs is built in then overall size), here's a topic: Discussing the Linux ARM kernel. I think that the actual cause of my problems.
Any opinion would be welcomed.
