Hi all,
I have a problem about jffs2, that I can't fix it. The original forum post is here i.mx28: fails to use jffs2
JFFS2 warning: (1075) jffs2_get_inode_nodes: Eep. No valid nodes for ino #26.
JFFS2 warning: (1075) jffs2_do_read_inode_internal: no data nodes found for ino #26
iget() failed for ino #26
I made a ramdisk using my rootfs and test read, write and erase of the nor flash, which is normal.
However when I start up the kernel using jffs2, I remain to see the errors.
Does anyone has used Winbond W25Q256FV with i.MX287 or has any device about this issue?
Thanks.
