i.mx yocto project build code very slow
tzeng015
hi all
I use my notebook to compiler the i.mx yocto project but it is very slow .
How can I do and what can I do ?
Please kindly help me.
thnak you
Jeffrey
khang_letruong
Senior Contributor III
To optimize the downloading time, you can edit following variable for saving the packages in a separate place :
DL_DIR ?= "${BSPDIR}/../yocto_dl/v5.10"
Once downloaded, next bitbaking will take less time and avoid issue with the network. Also, packages can also be shared for different working bsp folders to save disk space.
Rita_Wang
The build process is long, also the same in our side, it is related by the network and your PC performance.
