i.m53 ethernet port is not working till yesterday it was worked fine with cross over cable but not know what may be the problem with this
arunmondkar
hello sir i am using i.mx53 free scale  board till yesterday my board detected ethenet and led was bliked but not now what wiil be the problem  i am unable find i connected with cross over cable
SergioSolis
Hello Arun,
Are you using an i.MX53QSB ?, you have always connected it with a crossover cable?, and it was working with the same cable right?, do you have another known good cable to try it with?
arunmondkar
yes sir i am using i.mx53QSB, i connected board to to my host using crosswire cable only but its not working and also my i decided to try on another way like loading uboot and kernel and rootfs using memorycard by doing the partitions but am not able to get uboot logs i thought of that is their problem with uboot image which is provided by freescale images is this correct sir?
