i build the core image minimal by following this link
648 次查看
zubayrbhutta
GitHub - Freescale/fsl-community-bsp-platform: BSP platform manifest. Now i needed a tool chain to compile the programs for imx7dsabresd machine but the error generated after executing the bitbake command is
    class FuncFailed(Exceptionls):
NameError: name 'Exceptionls' is not defined.
Any ideas?
581 次查看
gusarambula
Hello  Zubayr Bhutta,
Which command are you using to build the toolchain?
$ bitbake meta-toolchain
This should suffice to generate the toolchain installer for your machine.
Would you please include the log file in order to see what recipe is generating an error?
