i.Mx8mm 改1g ddr4
i.Mx8mm 改1g ddr4
shaotang
我按照MX8Mmini_4.14.78_ga_BootLoader_V1-20190118_chn.pdf 修改了uboot中的ddr参数,改为了1gb的ddr4,ddr-timing.c时使用Config Tools for i.MX v10制作的,连接usb启动后log如下:
(mchunkptr p addr is 42200000
inuse(p)=1
next=42201340
inuse(p)=0
next=42200ff0
以及数字是我设置的断点打印)
我是不是漏改了一些东西?请给予我一些帮助,万分感谢!
BiyongSUN
You have training failed in the log.
Training FAILED
DRAM PHY training for 2400MTS
check ddr4_pmu_train_imem code
check ddr4_pmu_train_imem code pass
check ddr4_pmu_train_dmem code
check ddr4_pmu_train_dmem code pass
[PMU Major message = 0x00000008]
PMU String index = 0x013e0000
Rita_Wang
