If an i.Mx8QXPlus M4 Ethernet is configured for an application use ,how much will be the maximum speed it supports ,is it 10/100Mbps ? Is it possible to configure it for 1 Gbps . Could you please confirm.
Jithesh
Solved! Go to Solution.
Hi Igor
Thanks for the quick response .
M4 Processor runs in 200Mhz is this enough to process the Gigabit ethernet speed.
Jithesh
Hi Jithesh
these are different modules, running separately one from each other.
Also ENET module has own DMA engine.
Hi Igor,
Thanks for the response.
Here my requirement is to connect 1ENET module to M4 and 1ENET module to A35 Core ,in both case required to get performance of 1 Gigabit maximum. So I can enable DMA parallelly(is it possible ?) in both Cases to get maximum performance. Could you please confirm my understanding is correct.
Jithesh
Hi Jithesh
yes this is correct understanding.
Hi Igor
Thanks for the confirmation.
Jithesh
Hi Jithesh
ENET module perfomance (Ethernet speed) does not depend which core is using it, so max. speed
can be as described in datasheet 1000-Mbit/s.
