i.Mx28, is there a way to change a device driver without rebuild zImage?
1,199 次查看
jlu
the CAN device driver at 2.6.35 does not output frames in the right order. we have fixed the issue in a later version. now I want to know how to push that fix to older devices already out in the field.
标签 (2)
5 回复数
1,073 次查看
igorpadykov
Hi jill jlu
I am afraid there is no way to push that fix without rebuilding image.
1,073 次查看
jlu
Hello igor,
Then is there a way to dynamically override a driver? Hard to believe an error in device drivers has to trigger a recall.
Thank you very much,
Jill
1,073 次查看
igorpadykov
Hi Jill
could you clarify for "dynamically override a driver", probably point to some example.
1,073 次查看
jlu
Hello igor,
I mean override a driver after zImage has loaded, in anyway. I don't know how to do it.
Specifically, I use socketcan. In the kernel the socketcan uses can driver; the can driver uses flexcan driver. The flexcan driver has bugs. I am looking for a way to load a new can driver (or flexcan driver) as loadable module and bind the socketcan to this new can driver. This new module will not be in the zImage. How to achieve that?
thank you,
Jill
1,073 次查看
igorpadykov
Hi Jill
I am afraid this is not feasible, sorry.
