i.MX93 MIPI DSI with 640x480 mode
AlanWen
I'm using the DSI output of IMX93 for multiple resolutions, but only with 640x480 can't output as well.
The device tree and driver setup is as below:
&lcdif {
	status = "okay";
	/delete-property/ assigned-clock-rates;
	assigned-clock-rates = <519555554>, <74222222>, <400000000>, <133333333>;
static const struct imx_fracn_gppll_rate_table fracn_tbl[] = {
	PLL_FRACN_GP(1039500000U, 173, 25, 100, 1, 4),
	PLL_FRACN_GP(650000000U, 162, 50, 100, 0, 6),
	PLL_FRACN_GP(594000000U, 198, 0, 1, 0, 8),
	PLL_FRACN_GP(560000000U, 140, 0, 1, 0, 6),
	PLL_FRACN_GP(519750000U, 173, 25, 100, 1, 8),
	PLL_FRACN_GP(519555554U, 173, 5, 27, 0, 8),
	PLL_FRACN_GP(498000000U, 166, 0, 1, 0, 8),
	PLL_FRACN_GP(484000000U, 121, 0, 1, 0, 6),
	PLL_FRACN_GP(445333333U, 167, 0, 1, 0, 9),
	PLL_FRACN_GP(400000000U, 200, 0, 1, 0, 12),
	PLL_FRACN_GP(393216000U, 163, 84, 100, 0, 10),
	PLL_FRACN_GP(300000000U, 150, 0, 1, 0, 12),
After boot up, I test modetest on HDMI connector with resolution and it only output down to 1280x720 mode.
How can I add the 640x480 in to DSI ?
Tags (3)
AlanWen
I use imx-6.6.3-1.0.0 with imx-image-full bsp
Here is the boot up dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[    0.000000] Linux version 6.6.3-lts-next (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 13.2.0, GNU ld (GNU Binutils) 2.41.0.20230926) #1 SMP PREEMPT Thu Feb 29 16:37:44 CST 2024
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: NXP i.MX93 11X11 EVK board
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b0000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000b0000000..0x00000000bfffffff (262144 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x000000002021e000..0x000000002021efff (4 KiB) nomap non-reusable rsc-table@2021e000
[    0.000000] OF: reserved mem: 0x0000000096000000..0x0000000097dfffff (30720 KiB) nomap non-reusable optee_core@96000000
[    0.000000] OF: reserved mem: 0x0000000097e00000..0x0000000097ffffff (2048 KiB) nomap non-reusable optee_shm@97e00000
[    0.000000] OF: reserved mem: 0x00000000a4000000..0x00000000a4007fff (32 KiB) nomap non-reusable vdev0vring0@a4000000
[    0.000000] OF: reserved mem: 0x00000000a4008000..0x00000000a400ffff (32 KiB) nomap non-reusable vdev0vring1@a4008000
[    0.000000] OF: reserved mem: 0x00000000a4010000..0x00000000a4017fff (32 KiB) nomap non-reusable vdev1vring0@a4010000
[    0.000000] OF: reserved mem: 0x00000000a4018000..0x00000000a401ffff (32 KiB) nomap non-reusable vdev1vring1@a4018000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4020000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vdevbuffer@a4020000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4020000..0x00000000a411ffff (1024 KiB) nomap non-reusable vdevbuffer@a4020000
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4120000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node ele-reserved@a4120000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000a4120000..0x00000000a421ffff (1024 KiB) nomap non-reusable ele-reserved@a4120000
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000c0000000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node ethosu_region@C0000000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x00000000c0000000..0x00000000cfffffff (262144 KiB) map reusable ethosu_region@C0000000
[    0.000000] earlycon: lpuart32 at MMIO32 0x0000000044380000 (options '')
[    0.000000] printk: bootconsole [lpuart32] enabled
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xffbca6c0-0xffbccfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x0000000095ffffff]
[    0.000000]   node   0: [mem 0x0000000098000000-0x00000000a3ffffff]
[    0.000000]   node   0: [mem 0x00000000a4000000-0x00000000a421ffff]
[    0.000000]   node   0: [mem 0x00000000a4220000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000] On node 0, zone DMA: 8192 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 22 pages/cpu s50536 r8192 d31384 u90112
[    0.000000] pcpu-alloc: s50536 r8192 d31384 u90112 alloc=22*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Qualcomm erratum 1009, or ARM erratum 1286807, 2441009
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyLP0,115200 earlycon root=/dev/mmcblk1p2 rootwait rw
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 507904
[    0.000000] Policy zone: DMA
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 2.
[    0.000000] software IO TLB: mapped [mem 0x00000000f9800000-0x00000000fd800000] (64MB)
[    0.000000] Memory: 1395132K/2064384K available (21120K kernel code, 1756K rwdata, 8104K rodata, 4288K init, 635K bss, 144964K reserved, 524288K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000048040000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.008360] Console: colour dummy device 80x25
[    0.012600] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.022773] pid_max: default: 32768 minimum: 301
[    0.027410] LSM: initializing lsm=capability,integrity
[    0.032553] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.039848] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.048305] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    0.054693] RCU Tasks: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.061545] RCU Tasks Trace: Setting shift to 1 and lim to 1 rcu_task_cb_adjust=1.
[    0.069166] rcu: Hierarchical SRCU implementation.
[    0.073788] rcu: 	Max phase no-delay instances is 1000.
[    0.079881] EFI services will not be available.
[    0.084388] smp: Bringing up secondary CPUs ...
[    0.089070] Detected VIPT I-cache on CPU1
[    0.089129] GICv3: CPU1: found redistributor 100 region 0:0x0000000048060000
[    0.089165] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[    0.089268] smp: Brought up 1 node, 2 CPUs
[    0.110618] SMP: Total of 2 processors activated.
[    0.115289] CPU features: detected: 32-bit EL0 Support
[    0.120412] CPU features: detected: 32-bit EL1 Support
[    0.125517] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.134100] CPU features: detected: Common not Private translations
[    0.140333] CPU features: detected: CRC32 instructions
[    0.145456] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.151167] CPU features: detected: LSE atomic instructions
[    0.156713] CPU features: detected: Privileged Access Never
[    0.162258] CPU features: detected: RAS Extension Support
[    0.167635] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.174614] CPU: All CPU(s) started at EL2
[    0.178640] alternatives: applying system-wide alternatives
[    0.188591] devtmpfs: initialized
[    0.197069] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.206568] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[    0.220357] pinctrl core: initialized pinctrl subsystem
[    0.226902] DMI not present or invalid.
[    0.230933] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.237228] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.244099] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.251804] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.259668] audit: initializing netlink subsys (disabled)
[    0.265150] audit: type=2000 audit(0.176:1): state=initialized audit_enabled=0 res=1
[    0.265541] thermal_sys: Registered thermal governor 'step_wise'
[    0.272708] thermal_sys: Registered thermal governor 'power_allocator'
[    0.278713] cpuidle: using governor menu
[    0.289267] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.295883] ASID allocator initialised with 65536 entries
[    0.301934] Serial: AMBA PL011 UART driver
[    0.305824] imx mu driver is registered.
[    0.309674] imx rpmsg driver is registered.
[    0.320043] imx93-pinctrl 443c0000.pinctrl: initialized IMX pinctrl driver
[    0.333746] platform 4ae10000.dsi: Fixed dependency cycle(s) with /soc@0/dsi@4ae10000/hdmi-bridge@0/ports/port@0/endpoint
[    0.344740] platform 4ae30000.lcd-controller: Fixed dependency cycle(s) with /soc@0/dsi@4ae10000/ports/port@0/endpoint
[    0.358206] Modules: 23744 pages in range for non-PLT usage
[    0.358217] Modules: 515264 pages in range for PLT usage
[    0.364262] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.376075] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.382315] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.389073] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.395314] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.402073] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.408314] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.415073] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.422896] ACPI: Interpreter disabled.
[    0.427475] iommu: Default domain type: Translated
[    0.432037] iommu: DMA domain TLB invalidation policy: strict mode
[    0.438431] SCSI subsystem initialized
[    0.442057] libata version 3.00 loaded.
[    0.442227] usbcore: registered new interface driver usbfs
[    0.447463] usbcore: registered new interface driver hub
[    0.452751] usbcore: registered new device driver usb
[    0.458638] mc: Linux media interface: v0.10
[    0.462691] videodev: Linux video capture interface: v2.00
[    0.468157] pps_core: LinuxPPS API ver. 1 registered
[    0.473047] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.482153] PTP clock support registered
[    0.486185] EDAC MC: Ver: 3.0.0
[    0.489667] scmi_core: SCMI protocol bus registered
[    0.494815] FPGA manager framework
[    0.498009] Advanced Linux Sound Architecture Driver Initialized.
[    0.504591] Bluetooth: Core ver 2.22
[    0.507920] NET: Registered PF_BLUETOOTH protocol family
[    0.513199] Bluetooth: HCI device and connection manager initialized
[    0.519521] Bluetooth: HCI socket layer initialized
[    0.524371] Bluetooth: L2CAP socket layer initialized
[    0.529404] Bluetooth: SCO socket layer initialized
[    0.534625] vgaarb: loaded
[    0.537718] clocksource: Switched to clocksource arch_sys_counter
[    0.543773] VFS: Disk quotas dquot_6.6.0
[    0.547473] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.554424] pnp: PnP ACPI: disabled
[    0.562927] NET: Registered PF_INET protocol family
[    0.567710] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.576021] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    0.584364] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.592008] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.599951] TCP bind hash table entries: 16384 (order: 7, 524288 bytes, linear)
[    0.607584] TCP: Hash tables configured (established 16384 bind 16384)
[    0.613971] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.620554] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    0.627767] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.633618] RPC: Registered named UNIX socket transport module.
[    0.639286] RPC: Registered udp transport module.
[    0.643954] RPC: Registered tcp transport module.
[    0.648632] RPC: Registered tcp-with-tls transport module.
[    0.654093] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.661279] PCI: CLS 0 bytes, default 64
[    0.665395] kvm [1]: IPA Size Limit: 40 bits
[    0.669432] kvm [1]: GICv3: no GICV resource entry
[    0.674176] kvm [1]: disabling GICv2 emulation
[    0.678608] kvm [1]: GIC system register CPU interface enabled
[    0.684422] kvm [1]: vgic interrupt IRQ9
[    0.688321] kvm [1]: VHE mode initialized successfully
[    0.694326] Initialise system trusted keyrings
[    0.698706] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[    0.705171] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.710980] NFS: Registering the id_resolver key type
[    0.715804] Key type id_resolver registered
[    0.719926] Key type id_legacy registered
[    0.723932] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.730596] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.737966] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
[    0.744227] 9p: Installing v9fs 9p2000 file system support
[    0.771944] Key type asymmetric registered
[    0.775775] Asymmetric key parser 'x509' registered
[    0.780662] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.788003] io scheduler mq-deadline registered
[    0.792510] io scheduler kyber registered
[    0.796514] io scheduler bfq registered
[    0.806380] EINJ: ACPI disabled.
[    0.815208] Bus freq driver module loaded
[    0.824895] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.833552] 44380000.serial: ttyLP0 at MMIO 0x44380010 (irq = 17, base_baud = 1500000) is a FSL_LPUART
[    0.842866] printk: console [ttyLP0] enabled
[    0.851285] printk: bootconsole [lpuart32] disabled
[    0.862516] 44390000.serial: ttyLP1 at MMIO 0x44390010 (irq = 18, base_baud = 1500000) is a FSL_LPUART
[    0.872597] 42590000.serial: ttyLP4 at MMIO 0x42590010 (irq = 19, base_baud = 1500000) is a FSL_LPUART
[    0.882576] 425a0000.serial: ttyLP5 at MMIO 0x425a0010 (irq = 20, base_baud = 1500000) is a FSL_LPUART
[    0.894421] imx-drm display-subsystem: parent device of /ldb-display-controller/lvds-channel@0 is not available
[    0.913653] loop: module loaded
[    0.918265] megasas: 07.725.01.00-rc1
[    0.927265] tun: Universal TUN/TAP device driver, 1.6
[    0.933053] thunder_xcv, ver 1.0
[    0.936327] thunder_bgx, ver 1.0
[    0.939566] nicpf, ver 1.0
[    0.943220] pps pps0: new PPS source ptp0
[    0.950740] fec 42890000.ethernet eth0: registered PHC device 0
[    0.958355] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    0.965588] hns3: Copyright (c) 2017 Huawei Corporation.
[    0.970938] hclge is initializing
[    0.974283] e1000: Intel(R) PRO/1000 Network Driver
[    0.979154] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.984917] e1000e: Intel(R) PRO/1000 Network Driver
[    0.989870] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.995794] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.001179] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.006803] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.013070] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.019196] sky2: driver version 1.30
[    1.023356] usbcore: registered new device driver r8152-cfgselector
[    1.029649] usbcore: registered new interface driver r8152
[    1.035548] VFIO - User Level meta-driver version: 0.3
[    1.043817] usbcore: registered new interface driver uas
[    1.049166] usbcore: registered new interface driver usb-storage
[    1.055215] usbcore: registered new interface driver usbserial_generic
[    1.061747] usbserial: USB Serial support registered for generic
[    1.067753] usbcore: registered new interface driver ftdi_sio
[    1.073505] usbserial: USB Serial support registered for FTDI USB Serial Device
[    1.080852] usbcore: registered new interface driver usb_serial_simple
[    1.087385] usbserial: USB Serial support registered for carelink
[    1.093487] usbserial: USB Serial support registered for flashloader
[    1.099848] usbserial: USB Serial support registered for funsoft
[    1.105863] usbserial: USB Serial support registered for google
[    1.111789] usbserial: USB Serial support registered for hp4x
[    1.117531] usbserial: USB Serial support registered for kaufmann
[    1.123624] usbserial: USB Serial support registered for libtransistor
[    1.130150] usbserial: USB Serial support registered for moto_modem
[    1.136415] usbserial: USB Serial support registered for motorola_tetra
[    1.143032] usbserial: USB Serial support registered for nokia
[    1.148861] usbserial: USB Serial support registered for novatel_gps
[    1.155213] usbserial: USB Serial support registered for siemens_mpi
[    1.161566] usbserial: USB Serial support registered for suunto
[    1.167489] usbserial: USB Serial support registered for vivopay
[    1.173492] usbserial: USB Serial support registered for zio
[    1.179157] usbcore: registered new interface driver usb_ehset_test
[    1.186799] imx_usb 4c100000.usb: No over current polarity defined
[    1.193121] imx_usb 4c200000.usb: No over current polarity defined
[    1.201492] input: 44440000.bbnsm:pwrkey as /devices/platform/soc@0/44000000.bus/44440000.bbnsm/44440000.bbnsm:pwrkey/input/input0
[    1.216768] bbnsm_rtc 44440000.bbnsm:rtc: registered as rtc1
[    1.223355] i2c_dev: i2c /dev entries driver
[    1.230176] qoriq_thermal 44482000.tmu: invalid range data.
[    1.237221] imx7ulp-wdt 442d0000.watchdog: imx93 wdt probe
[    1.273278] imx7ulp-wdt 42490000.watchdog: imx93 wdt probe
[    1.307638] Bluetooth: HCI UART driver ver 2.3
[    1.312119] Bluetooth: HCI UART protocol H4 registered
[    1.317253] Bluetooth: HCI UART protocol BCSP registered
[    1.322586] Bluetooth: HCI UART protocol LL registered
[    1.327713] Bluetooth: HCI UART protocol ATH3K registered
[    1.333113] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    1.339517] Bluetooth: HCI UART protocol Broadcom registered
[    1.345182] Bluetooth: HCI UART protocol QCA registered
[    1.352146] sdhci: Secure Digital Host Controller Interface driver
[    1.358352] sdhci: Copyright(c) Pierre Ossman
[    1.363240] Synopsys Designware Multimedia Card Interface Driver
[    1.369744] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.377169] ledtrig-cpu: registered to indicate activity on CPUs
[    1.384450] fsl-se-fw se-fw2: assigned reserved memory node ele-reserved@a4120000
[    1.393812] fsl-se-fw se-fw2: Successfully registered ele-trng
[    1.400010] fsl-se-fw se-fw2: i.MX secure-enclave: mu2 interface to firmware, configured.
[    1.400557] random: crng init done
[    1.408359] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.411640] mmc0: SDHCI controller on 42850000.mmc [42850000.mmc] using ADMA
[    1.418672] usbcore: registered new interface driver usbhid
[    1.430643] usbhid: USB HID core driver
[    1.436461] mxc-isi_v1 4ae40000.isi: mxc_isi.0 registered successfully
[    1.444091] ethosu ethosu: assigned reserved memory node ethosu_region@C0000000
[    1.490885] hw perfevents: enabled with armv8_cortex_a55 PMU driver, 7 counters available
[    1.491857] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.501345]  cs_system_cfg: CoreSight Configuration manager initialised
[    1.505955] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.513807] optee: probing for conduit method.
[    1.520419]  mmcblk0: p1 p2
[    1.520960] optee: revision 4.0 (e0a3e777)
[    1.524132] optee: dynamic shared memory is enabled
[    1.524332] mmcblk0boot0: mmc0:0001 DG4016 4.00 MiB
[    1.528602] optee: initialized driver
[    1.534173] mmcblk0boot1: mmc0:0001 DG4016 4.00 MiB
[    1.545557] NET: Registered PF_LLC protocol family
[    1.547494] mmcblk0rpmb: mmc0:0001 DG4016 4.00 MiB, chardev (234:0)
[    1.551641] u32 classifier
[    1.560411]     input device check on
[    1.564070]     Actions configured
[    1.567789] NET: Registered PF_INET6 protocol family
[    1.573507] Segment Routing with IPv6
[    1.577212] In-situ OAM (IOAM) with IPv6
[    1.581174] NET: Registered PF_PACKET protocol family
[    1.586245] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.599375] Bluetooth: RFCOMM TTY layer initialized
[    1.604265] Bluetooth: RFCOMM socket layer initialized
[    1.609417] Bluetooth: RFCOMM ver 1.11
[    1.613163] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.618467] Bluetooth: BNEP filters: protocol multicast
[    1.623683] Bluetooth: BNEP socket layer initialized
[    1.628637] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.634553] Bluetooth: HIDP socket layer initialized
[    1.639702] 8021q: 802.1Q VLAN Support v1.8
[    1.643913] lib80211: common routines for IEEE802.11 drivers
[    1.649559] lib80211_crypt: registered algorithm 'NULL'
[    1.649563] lib80211_crypt: registered algorithm 'WEP'
[    1.649566] lib80211_crypt: registered algorithm 'CCMP'
[    1.649569] lib80211_crypt: registered algorithm 'TKIP'
[    1.649607] 9pnet: Installing 9P2000 support
[    1.654000] Key type dns_resolver registered
[    1.670960] registered taskstats version 1
[    1.675204] Loading compiled-in X.509 certificates
[    1.704045] usb_phy_generic usbphynop1: dummy supplies not allowed for exclusive requests
[    1.712398] usb_phy_generic usbphynop2: dummy supplies not allowed for exclusive requests
[    1.736000] mipi-dsi 4ae10000.dsi.0: Fixed dependency cycle(s) with /soc@0/dsi@4ae10000/ports/port@1/endpoint
[    1.746065] panel-simple-dsi 4ae10000.dsi.0: supply power not found, using dummy regulator
[    1.755057] imx-drm display-subsystem: bound imx-lcdifv3-crtc.0 (ops lcdifv3_crtc_ops)
[    1.763089] imx-drm display-subsystem: bound 4ae10000.dsi (ops dw_mipi_dsi_imx_ops)
[    1.771120] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0
[    1.856809] Console: switching to colour frame buffer device 80x30
[    1.879888] imx-drm display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
[    1.891893] imx-dwmac 428a0000.ethernet: IRQ eth_lpi not found
[    1.896377] tpm_tis_spi spi0.0: 2.0 TPM (device-id 0xFC, rev-id 1)
[    1.904830] imx-dwmac 428a0000.ethernet: User ID: 0x10, Synopsys ID: 0x52
[    1.908965] tpm tpm0: A TPM error (256) occurred attempting the self test
[    1.911631] imx-dwmac 428a0000.ethernet: 	DWMAC4/5
[    1.918396] tpm tpm0: starting up the TPM manually
[    1.923176] imx-dwmac 428a0000.ethernet: DMA HW capability register supported
[    1.935071] imx-dwmac 428a0000.ethernet: RX Checksum Offload Engine supported
[    1.942198] imx-dwmac 428a0000.ethernet: TX Checksum insertion supported
[    1.948887] imx-dwmac 428a0000.ethernet: Wake-Up On Lan supported
[    1.955042] imx-dwmac 428a0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    1.962717] imx-dwmac 428a0000.ethernet: device MAC address c2:53:ec:f8:df:92
[    1.969849] imx-dwmac 428a0000.ethernet: Enabled L3L4 Flow TC (entries=8)
[    1.976630] imx-dwmac 428a0000.ethernet: Enabled RFS Flow TC (entries=10)
[    1.983418] imx-dwmac 428a0000.ethernet: Enabling HW TC (entries=256, max_off=256)
[    1.990975] imx-dwmac 428a0000.ethernet: Using 32/32 bits DMA host/device width
[    2.003656] imx_usb 4c100000.usb: No over current polarity defined
[    2.013318] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    2.018258] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    2.037723] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    2.043707] hub 1-0:1.0: USB hub found
[    2.047481] hub 1-0:1.0: 1 port detected
[    2.052585] imx_usb 4c200000.usb: No over current polarity defined
[    2.061862] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    2.066781] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[    2.089722] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    2.095710] hub 2-0:1.0: USB hub found
[    2.099496] hub 2-0:1.0: 1 port detected
[    2.107011] remoteproc remoteproc0: imx-rproc is available
[    2.127803] st_lsm6dsx_i2c 0-006a: supply vdd not found, using dummy regulator
[    2.135152] st_lsm6dsx_i2c 0-006a: supply vddio not found, using dummy regulator
[    2.201772] st_lsm6dsx_i2c 0-006a: failed to read whoami register
[    2.208025] st_lsm6dsx_i2c: probe of 0-006a failed with error -5
[    2.214147] i2c i2c-0: LPI2C adapter registered
[    2.357734] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[    2.520252] hub 2-1:1.0: USB hub found
[    2.524400] hub 2-1:1.0: 4 ports detected
[    3.225722] adp5585 1-0034: Failed to read reg 0x00, ret is -110
[    3.231747] adp5585: probe of 1-0034 failed with error -110
[    3.237731] i2c i2c-1: LPI2C adapter registered
[    3.244201] rtc-pcf85063 2-0051: registered as rtc0
[    3.249384] rtc-pcf85063 2-0051: setting system clock to 2024-09-25T10:04:42 UTC (1727258682)
[    3.258110] adp5585 2-0034: Failed to read reg 0x00, ret is -5
[    3.263939] adp5585: probe of 2-0034 failed with error -5
[    3.269528] i2c 2-003c: Fixed dependency cycle(s) with /soc@0/bus@42800000/camera/csi@4ae00000/port/endpoint
[    3.279576] i2c i2c-2: LPI2C adapter registered
[    3.284980] i2c i2c-4: LPI2C adapter registered
[    3.292116] dwc-mipi-csi2-host 4ae00000.csi: lanes: 2, name: mxc-mipi-csi2.0
[    3.292510] sdhci-esdhc-imx 42860000.mmc: Got CD GPIO
[    3.315178] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.324232] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.330009] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    3.338729] clk: Disabling unused clocks
[    3.342874] mmc1: SDHCI controller on 42860000.mmc [42860000.mmc] using ADMA
[    3.349972] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[    3.357841] ALSA device list:
[    3.360808]   No soundcards found.
[    3.510871] mmc1: host does not support reading read-only switch, assuming write-enable
[    3.543553] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[    3.550684] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[    3.560678]  mmcblk1: p1 p2
[    4.233726] nxp-pca9450 1-0025: Read device id error
[    4.238772] nxp-pca9450: probe of 1-0025 failed with error -110
[    4.366206] EXT4-fs (mmcblk1p2): mounted filesystem 84fe4d3f-40df-4b1c-9e76-94764eeb65bb r/w with ordered data mode. Quota mode: none.
[    4.378381] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.387815] devtmpfs: mounted
[    4.392304] Freeing unused kernel memory: 4288K
[    4.396956] Run /sbin/init as init process
[    4.401049]   with arguments:
[    4.401051]     /sbin/init
[    4.401054]   with environment:
[    4.401056]     HOME=/
[    4.401058]     TERM=linux
[    4.649564] systemd[1]: systemd 254.4^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    4.681402] systemd[1]: Detected architecture arm64.
[    4.754772] systemd[1]: Hostname set to <imx93evk>.
[    4.870604] systemd-sysv-generator[106]: SysV service '/etc/init.d/umountnfs.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    4.902437] systemd-sysv-generator[106]: SysV service '/etc/init.d/trousers' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    4.932997] systemd-sysv-generator[106]: SysV service '/etc/init.d/halt' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    4.963148] systemd-sysv-generator[106]: SysV service '/etc/init.d/sshd' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    4.999714] systemd-sysv-generator[106]: SysV service '/etc/init.d/openvpn' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.030325] systemd-sysv-generator[106]: SysV service '/etc/init.d/rc.local' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.061385] systemd-sysv-generator[106]: SysV service '/etc/init.d/umountfs' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.092946] systemd-sysv-generator[106]: SysV service '/etc/init.d/single' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.123367] systemd-sysv-generator[106]: SysV service '/etc/init.d/sendsigs' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.155896] systemd-sysv-generator[106]: SysV service '/etc/init.d/save-rtc.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.187239] systemd-sysv-generator[106]: SysV service '/etc/init.d/fuse' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.217500] systemd-sysv-generator[106]: SysV service '/etc/init.d/psplash.sh' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.248161] systemd-sysv-generator[106]: SysV service '/etc/init.d/tee-supplicant' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.279194] systemd-sysv-generator[106]: SysV service '/etc/init.d/network-manager' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.312859] systemd-sysv-generator[106]: SysV service '/etc/init.d/reboot' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    5.658028] systemd[1]: Queued start job for default target Graphical Interface.
[    5.708185] systemd[1]: Created slice Slice /system/getty.
[    5.731677] systemd[1]: Created slice Slice /system/modprobe.
[    5.755638] systemd[1]: Created slice Slice /system/serial-getty.
[    5.779143] systemd[1]: Created slice User and Session Slice.
[    5.802137] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.826099] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.850118] systemd[1]: Reached target Remote File Systems.
[    5.869925] systemd[1]: Reached target Slice Units.
[    5.889935] systemd[1]: Reached target Swaps.
[    5.946028] systemd[1]: Listening on RPCbind Server Activation Socket.
[    5.969993] systemd[1]: Reached target RPC Port Mapper.
[    5.990511] systemd[1]: Listening on Syslog Socket.
[    6.010233] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    6.034849] systemd[1]: Listening on Journal Audit Socket.
[    6.058416] systemd[1]: Listening on Journal Socket (/dev/log).
[    6.082508] systemd[1]: Listening on Journal Socket.
[    6.102636] systemd[1]: Listening on Network Service Netlink Socket.
[    6.132320] systemd[1]: Listening on udev Control Socket.
[    6.154369] systemd[1]: Listening on udev Kernel Socket.
[    6.174417] systemd[1]: Listening on User Database Manager Socket.
[    6.214216] systemd[1]: Mounting Huge Pages File System...
[    6.241567] systemd[1]: Mounting POSIX Message Queue File System...
[    6.286209] systemd[1]: Mounting Kernel Debug File System...
[    6.310176] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    6.330187] systemd[1]: Mounting Temporary Directory /tmp...
[    6.354628] systemd[1]: Starting Create List of Static Device Nodes...
[    6.398421] systemd[1]: Starting Load Kernel Module configfs...
[    6.425931] systemd[1]: Starting Load Kernel Module drm...
[    6.450034] systemd[1]: Starting Load Kernel Module fuse...
[    6.466545] fuse: init (API version 7.39)
[    6.522408] systemd[1]: Starting RPC Bind...
[    6.542091] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[    6.560137] systemd[1]: Starting Journal Service...
[    6.602510] systemd[1]: Starting Load Kernel Modules...
[    6.610601] systemd-journald[121]: Collecting audit messages is enabled.
[    6.626623] systemd[1]: Starting Generate network units from Kernel command line...
[    6.654645] systemd[1]: Starting Remount Root and Kernel File Systems...
[    6.682437] systemd[1]: Starting Coldplug All udev Devices...
[    6.718588] EXT4-fs (mmcblk1p2): re-mounted 84fe4d3f-40df-4b1c-9e76-94764eeb65bb r/w. Quota mode: none.
[    6.728795] systemd[1]: Starting Virtual Console Setup...
[    6.763709] systemd[1]: Started RPC Bind.
[    6.790561] systemd[1]: Started Journal Service.
[    7.199814] systemd-journald[121]: Received client request to flush runtime journal.
[    7.476165] audit: type=1334 audit(1727258686.724:2): prog-id=5 op=LOAD
[    7.483337] audit: type=1334 audit(1727258686.732:3): prog-id=6 op=LOAD
[    7.973907] audit: type=1334 audit(1727258687.220:4): prog-id=7 op=LOAD
[    7.990443] audit: type=1334 audit(1727258687.232:5): prog-id=8 op=LOAD
[    9.714674] audit: type=1334 audit(1727258688.964:6): prog-id=9 op=LOAD
[    9.714973] audit: type=1334 audit(1727258688.964:7): prog-id=10 op=LOAD
[   10.201828] RTL8211F Gigabit Ethernet 42890000.ethernet-1:02: attached PHY driver (mii_bus:phy_addr=42890000.ethernet-1:02, irq=POLL)
[   10.257199] imx-dwmac 428a0000.ethernet eth1: Register MEM_TYPE_PAGE_POOL RxQ-0
[   10.353914] imx-dwmac 428a0000.ethernet eth1: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   10.361803] imx-dwmac 428a0000.ethernet eth1: No Safety Features support found
[   10.361837] imx-dwmac 428a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[   10.363026] imx-dwmac 428a0000.ethernet eth1: registered PTP clock
[   10.389847] imx-dwmac 428a0000.ethernet eth1: FPE workqueue start
[   10.389870] imx-dwmac 428a0000.ethernet eth1: configuring for phy/rgmii-id link mode
[   10.422438] 8021q: adding VLAN 0 to HW filter on device eth1
[   10.852732] audit: type=1334 audit(1727258690.100:8): prog-id=11 op=LOAD
[   10.873812] audit: type=1334 audit(1727258690.120:9): prog-id=12 op=LOAD
[   11.900747] CAN device driver interface
[   12.051129] imx8_media_dev: module is from the staging directory, the quality is unknown, you have been warned.
[   12.146348] mx8-img-md: Registered mxc_isi.0.capture as /dev/video0
[   12.323567] unregister ISI channel: mxc_isi.0
[   12.430808] tlv320aic3x 1-001b: supply IOVDD not found, using dummy regulator
[   12.492051] fsl_mc_err_probe: No ECC DIMMs discovered
[   12.594191] tlv320aic3x 1-001b: supply DVDD not found, using dummy regulator
[   12.693058] tlv320aic3x 1-001b: supply AVDD not found, using dummy regulator
[   12.832898] tlv320aic3x 1-001b: supply DRVDD not found, using dummy regulator
[   12.897860] tlv320aic3x 1-001b: Invalid supply voltage(s) AVDD: -22, DVDD: -22
[   14.235012] EXT4-fs (mmcblk0p2): mounted filesystem a6b3510b-795e-49bc-8714-f14aeed7531a r/w with ordered data mode. Quota mode: none.
[   14.314662] fec 42890000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   14.519908] flexcan 443a0000.can can0: bit-timing not yet defined
[   14.728295] flexcan 425b0000.can can1: bit-timing not yet defined
[   14.959994] audit: type=1006 audit(1727258694.208:10): pid=727 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[   14.972432] audit: type=1300 audit(1727258694.208:10): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffc8298c20 a2=1 a3=1 items=0 ppid=1 pid=727 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" key=(null)
[   14.998759] audit: type=1327 audit(1727258694.208:10): proctitle="(systemd)"
[   15.026771] audit: type=1334 audit(1727258694.276:11): prog-id=13 op=LOAD
[   15.034263] audit: type=1300 audit(1727258694.276:11): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffd64bfbd8 a2=90 a3=0 items=0 ppid=1 pid=727 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   15.060849] audit: type=1327 audit(1727258694.276:11): proctitle="(systemd)"
[   15.069550] audit: type=1334 audit(1727258694.276:12): prog-id=13 op=UNLOAD
[   15.076734] audit: type=1300 audit(1727258694.276:12): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffac50c500 items=0 ppid=1 pid=727 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" key=(null)
[   15.102426] audit: type=1327 audit(1727258694.276:12): proctitle="(systemd)"
[   15.110463] audit: type=1334 audit(1727258694.276:13): prog-id=14 op=LOAD
[   16.002789] weston[688]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   20.176315] systemd-journald[121]: Time jumped backwards, rotating.
[   23.183836] i2c 2-003c: deferred probe pending
[   23.188321] platform imx93-lpm: deferred probe pending
[   23.193471] platform regulator-avdd: deferred probe pending
[   23.199068] platform regulator-audio-pwr: deferred probe pending
[   23.205082] platform regulator-dvdd_sel: deferred probe pending
[   23.211010] platform regulator-dvdd: deferred probe pending
[   23.216587] platform regulator-vdd: deferred probe pending
[   23.222082] platform regulator-vddo: deferred probe pending
[   41.637970] kauditd_printk_skb: 8 callbacks suppressed
[   41.637980] audit: type=1334 audit(1727258720.431:16): prog-id=12 op=UNLOAD
[   41.650346] audit: type=1334 audit(1727258720.431:17): prog-id=11 op=UNLOAD
joanxie
do you mind giving me the modetest result and use the command below
echo 0x04 > /sys/module/drm/parameters/debug, then give me the dmesg
joanxie
what bsp do you test? when you use 640x480 mode, what kind of error message do you get? pls share the dmesg with me
