I am investigating running Bare Metal code (such as a program with Zephyr RTOS) on the A-55 cores of the i.MX93 EVK. Is there much information on how to go about debugging an application that is running in this way with a SEGGER J-Link?
I have been able to follow the Real-Time Edge user guide as far as getting an SD card with a copy of the bare metal U-Boot running. I can then stop the autoboot from there to run the Zephyr synchronisation example on core 1 as suggested in the Zephyr documentation for the board. Unfortunately my knowledge ends there on how we would go about setting up debugging for a program using a debugger, and I can't find much information around in documentation.
Sean
Not is nxp, You can find more information on https://www.zephyrproject.org/ and segger.com
