Hi.
I've been designing i.mx8m plus board that using LVDS. Now I try to fix the EMI matters on lvds signal to adjust the lvds signal strength with using "CC_ADJ" bits on LVDS_CTRL Register. (Naturally, lvds's tx/rx impedance is already matched at 100Ω.)
Some LVDS_CTRL Register bit description has not present specific values on i.MX8M Plus Reference Manual (screenshot attatched). Does NXP has any information for those registers ?
Solved! Go to Solution.
Hi Hiroaki
additional description was sent you via mail.
Hi Hiroaki
Hi Igor,
I also need this information .
could you please share this information with me.
Yogesh
HI NXP Team,
I need also this information.
Can you also share with me?
Marcel
