How to set ZQ_RESISTOR_SHARED in the Register Script Aids for below LPDDR4 connection?
ZQ_RESISTOR_SHARED | - | 0 | 00000000 | Description: Shared ZQ resistor between ranks. |
Solved! Go to Solution.
Hi m_c
one can refer to below answer:
https://community.nxp.com/t5/i-MX-Processors/Shared-ZQ-resistor/m-p/953291
If you use two-rank LPDDR4 and have two ZQ resistors, you set it to DISABLED.
Hi m_c
