i.MX8ULP pinout and multiplexing table
1,736 次查看
Cécile__
In section 9.1 of the document IMX8ULPIEC, we have :
"See the attached IO Definition and Package Ballmap spreadsheet for the pinout table of 485 MAPBGA package."
However, I can't find this document...
Can yout tell me where is this document ?
Thank you for your help,
Cécile
1,711 次查看
Cécile__
I can't find this file with firefox, however, it works with okular !
Thank you for your help !
Cécile
4 回复数
1,712 次查看
Cécile__
Cécile
388 次查看
PythoniumPro
Merci, vous êtes ma sauveuse!
Thank you, you are my savior!
1,719 次查看
Chavira
Hi @Cécile__!
Thank you for contacting NXP Support!
The document is attached to the Datasheet (check the attached photo)
If you can't find it, I will send you the file by mail.
Best Regards!
Chavira
459 次查看
SSchmitz
Same here,
I am also looking for the IO definition as mentioned at 9.1 i.MX 8ULP pin multiplexing.
Is there any place where i can download the Ballmap spreadsheet?
Sebastian Schmitz
