In section 9.1 of the document IMX8ULPIEC, we have :
"See the attached IO Definition and Package Ballmap spreadsheet for the pinout table of 485 MAPBGA package."
However, I can't find this document...
Can yout tell me where is this document ?
Thank you for your help,
Cécile
Solved! Go to Solution.
I can't find this file with firefox, however, it works with okular !
Thank you for your help !
Cécile
Cécile
Hi @Cécile__!
Thank you for contacting NXP Support!
The document is attached to the Datasheet (check the attached photo)
If you can't find it, I will send you the file by mail.
Best Regards!
Chavira
