i.MX8QXP/i.MX8M-PLUS GPIO pads typical capacitance value
aviad_h
Senior Contributor I
Can you please provide the typical capacitance CL values for i.MX8QXP, i.MX8M-PLUS CPUs. For the i.MX8M-PLUS only mention of CL I found is in section 3.5.1 of the datasheet but this does not state the typical values. We see different behavior in RGMII signals' timing in i.MX8QXP/i.MX8QM vs i.MX8M-PLUS and wish to check if there are differences in this parameter between the two families
Thanks for your support!
Yuri
