i.MX8QXP Ethernet PHY alternative for AR8031
ET_Dev
Hello
We are working on a new design using the i.MXQXP MEK as reference and one of the key component that is onselete is the AR8031-AL1B used on the design. We are looking for a replacement for the same that is already supported by the NXP Linux and Android BSPs.
This is a new design and we can use any part with easy availability and this not a NRND part. Any recommendations along these lines will be very useful.
Thanks.
JorgeCas
I received a reply from internal team:
We have no plan to replace the AR8031 so far. Our demo board is just a reference design. Customer can choose the ethernet PHY chip according to their requirements.
Best regards.
Jorge.
JorgeCas
I hope you are doing well.
The ethernet PHYs supported by default on the BSP are the next:
But we do not have a list of recommended parts as an alternative for AR8031.
I suggest you look for part numbers with similar characteristics.
Best regards.
Jorge.
ET_Dev
Thanks for the reply, is it possible for you to check with your internal teams, as they might be working on a replacement for the AR8031, considering it is a sunset part.
For the Automotive Ethernet PHY we are using TJA1101, instead of the TJA1100 since that is used on the reference board OM14500/TJA1101, assuming that NXP BSP would have support for this.
JorgeCas
Best regards.
Jorge.
JorgeCas
Sure, I will update you as soon as possible.
Best regards.
