i.MX8QM Yocto adb issue
1,783 次查看
yifei_ren
Hello ,NXP developer:
I am working on Imx8qxp and yocto project.
I added adb on this linux project, but I found something wrong with adb permission.
When I use this command "# ifconfig can0 up".
If using serial port login,this command works .
But when I using adb login ,also I already get root permissions.
this command can not work and shows permission deny like below.
         root@imx8qxpmek:~# ifconfig can0 up
         ifconfig: SIOCSIFADDR: Operation not permitted
I alreay tried add shell to root group.
In adb bash,using who like below
         root@imx8qxpmek:~# who
         root ttyLP0 Jun 13 08:10
Also tried chmod +s /sbin/ifconfig . but still not work.
Do you have any idea about this issue?
标记 (2)
1,429 次查看
yifei_ren
adb drop privileges it self, in adb.c files just skip it
1,429 次查看
li_hong
Hi,yifei ren:
How to porting adb function to Yocto?
1,430 次查看
yifei_ren
1,429 次查看
yifei_ren
  • Does anyone else have this problem?
