I use USB OTG2 + SS3 to form a USB3.0 TYPE A, I need OTG2 can not only down load system but also work as host.
The Type-A port can download the system now ,but can’t recognize usb2.0/3.0 device.
If I need to change U-boot config or other files?
PS :I have pulled low OTG2-ID pin to GND,and change U-boot imx8qm_mek_defconfig in attached.
Solved! Go to Solution.
Hi George
one can try to change U-boot imx8qm_mek_defconfig
#CONFIG_USB_TCPC=n
Hi George
#CONFIG_USB_TCPC=n
