i.MX8QM Rotate the display in SDK side
vinothkumars
Senior Contributor IV
Hi All,
I am using i.MX8QM with LVDS to HDMI display I needs to rotate the display in different degree like 0, 90, 180 in M4 Core. M4 Core using spl-imx8qm.bin file.
I would like to modify in M4 core in the following SDK for following application,
SDK: SDK_MEK-MIMX8QM
Application: RVC
Display : DPU
source: SPL
Is there any display hardware register to rotate the display ?
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
Hi Vinoth
linux patch was sent via mail.
vinothkumars
Thank you igorpadykov‌ for your quick reply.
But, I am unable to find out patch for SDK_MEK-MIMX8QM
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
Hi Vinoth
unfortunately I am not aware of similar patch for SDK,
vinothkumars
Thank you Igorpadykov,
Will you please forward to your team ?
Thanks & Regards,
Vinoth S,
Vinothkumar Sekar
probably one can try edma or neon and rotate frame image in software.
c - Transpose a 2D array - Stack Overflow
vinothkumars
Thank you Igor,
Vinoth S,
Vinothkumar Sekar
