i.MX8MQ changing ENET_REF_CLK_ROOT source from 25M_REF_CLK to PLL and enabling spread spectrum mode
1,435件の閲覧回数
harshitshah
We are facing some EMI-related issues on our board. We wanted to change the following to check the reduction in EMI.
1) Change the ENET_REF_CLK_ROOT source from 25M_REF_CLK to PLL1 (We found by reading the CCM_TARGET_ROOT83)
2) Enable the spread spectrum mode and set it to center and 0.25.
Please provide us with how to modify the same in the Linux kernel.
Regards.
2 返答(返信)
1,424件の閲覧回数
harshitshah
Thanks Igor. I will check with those links.
Can you comment on how to enable spread spectrum mode in linux kernel as well?
Regards.
1,426件の閲覧回数
Hi Harshit
for changing clock source in device tree one can look at below examples
https://community.nxp.com/t5/i-MX-Processors/Where-pll4-bypass-src-is-set-to-choose-osc-24MHz-or-CLK...
https://community.nxp.com/t5/i-MX-Processors/i-MX7D-24MHz-clock-output-to-CCM-CLK1-P-pin/m-p/650813
Unfortunately I am not aware of spread spectrum mode examples, so may be recommended to proceed with
help of  https://contact.nxp.com/new-prof-svcs-sw-tech  for developing them.
