i.MX8MQ – Initial code loading without USB/UUU using
722 次查看
ayse-yilmaz
We are developing a custom embedded system using the NXP i.MX8MQ processor. Due to strict space constraints in our hardware design, we cannot expose a USB port in the final product.
System Summary:
Processor: i.MX8MQ
RAM: 4GB DDR4
Storage: External eMMC
Intended OS: Yocto Linux running on Cortex-A53
No initial bootloader or software flashed yet (fully blank system)
Available debug interface: JTAG (SEGGER J-Link)
Our main question is:
Can we use JTAG (via J-Link) to initialize DDR and load and execute code (such as U-Boot) in RAM without using USB or the internal boot ROM boot process (i.e., bypassing UUU tool)?
Or is it mandatory to use the USB OTG + UUU serial downloader at least once to load initial code to the system before we can boot from eMMC?
Thank you very much for your help.
5 回复数
714 次查看
Bio_TICFSL
Yes you can use jtag or you can program the eMMC or SDcard separately.
regards
695 次查看
ayse-yilmaz
Thank you for your support.
I found documentation related to loading firmware via JTAG on the M4 core, but I could not find similar documentation for the Cortex-A53 core.
Could you please provide or point me to any official documentation or resources about loading and running code on the Cortex-A53 core (i.MX8MQ) using JTAG (e.g., with SEGGER J-Link)?
646 次查看
Bio_TICFSL
one can look on
IDE - Debug, Compile and Build Tools (2)
SDK_2.3_MX8MQ_Beta_Patch(REV SDK2.3_MX8MQ_Beta)
(NXP provided IAR and Segger tool patch to support i.MX8MQuad device)
i.MX 8M Evaluation Kit|NXP
for A53 supported  Lauterbach and ARM DS-5, for OpenOCD one can look at a53 support on
Programming Guide: OpenOCD + Eclipse + Jtag debug on Uboot & Linux
585 次查看
ayse-yilmaz
Thank you for the references.
I have checked the SDK and toolchain patch links as well as the OpenOCD documentation you mentioned, but I could not find a clear and complete example or guide showing how to:
      * Initialize DDR from JTAG on i.MX8MQ (Cortex-A53),
      * Load and execute U-Boot or any custom binary directly into A53 RAM via JTAG (e.g., with SEGGER J-Link),
      * Do this entirely without using the internal boot ROM mechanisms (i.e., without USB/Serial Downloader Mode).
Most available documentation seems to either:
     *  Target the Cortex-M4 core,
     *  Assume a bootloader is already present, or
     *  As in the reference you provided, demonstrate debugging U-Boot and kernel via JTAG only after they have been loaded through USB and the UUU tool, rather than performing a full bring-up from a blank device.
Could you please clarify if it is officially supported to boot Cortex-A53 code via JTAG (without USB), and if so, could you provide:
      * a direct application note, app guide, or example script (J-Link, Lauterbach, DS-5, or OpenOCD)
      * or any steps regarding DDR training, code upload, and A53 startup via JTAG?
This would be very helpful for bringing up our custom hardware which currently has no pre-flashed bootloader and no USB access.
Thank you again for your support.
标记 (1)
569 次查看
Bio_TICFSL
For JTAG and JLink scripts supporting Cortex-A53, may be recommended to apply to segger directly:
https://forum.segger.com/index.php/Thread/4447-SOLVED-Cortex-A53-support/
NXP uses Lauterbach Trace32 as debugger tool for Cortex-A53 cores.
%3CLINGO-SUB%20id%3D%22lingo-sub-2130958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8MQ%20-%20%E5%9C%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%20USB%2FUUU%20%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%8A%A0%E8%BD%BD%E5%88%9D%E5%A7%8B%E4%BB%A3%E7%A0%81%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E4%B8%80%E4%B8%AA%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20i.MX8MQ%20%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E5%AE%9A%E5%88%B6%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%B3%BB%E7%BB%9F%E3%80%82%E7%94%B1%E4%BA%8E%E7%A1%AC%E4%BB%B6%E8%AE%BE%E8%AE%A1%E7%9A%84%E7%A9%BA%E9%97%B4%E9%99%90%E5%88%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E5%9C%A8%E6%9C%80%E7%BB%88%E4%BA%A7%E5%93%81%E4%B8%AD%E4%BD%BF%E7%94%A8%20USB%20%E7%AB%AF%E5%8F%A3%E3%80%82%3C%2FP%3E%3CP%3E%E7%B3%BB%E7%BB%9F%E6%A6%82%E8%A6%81%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%EF%BC%9Ai.MX8MQ%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%EF%BC%9A%204GB%20DDR4%3C%2FP%3E%3CP%3E%E5%AD%98%E5%82%A8%E7%A9%BA%E9%97%B4%E5%A4%96%E7%BD%AE%20eMMC%3C%2FP%3E%3CP%3E%E7%9B%AE%E6%A0%87%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E5%9C%A8%20Cortex-A53%20%E4%B8%8A%E8%BF%90%E8%A1%8C%E7%9A%84%20Yocto%20Linux%3C%2FP%3E%3CP%3E%E5%B0%9A%E6%9C%AA%E5%88%B7%E6%96%B0%E5%88%9D%E5%A7%8B%E5%90%AF%E5%8A%A8%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%88%96%E8%BD%AF%E4%BB%B6%EF%BC%88%E7%B3%BB%E7%BB%9F%E5%AE%8C%E5%85%A8%E7%A9%BA%E7%99%BD%EF%BC%89%3C%2FP%3E%3CP%3E%E5%8F%AF%E7%94%A8%E7%9A%84%E8%B0%83%E8%AF%95%E6%8E%A5%E5%8F%A3%EF%BC%9AJTAG%EF%BC%88SEGGER%20J-Link%EF%BC%89%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%BB%E8%A6%81%E9%97%AE%E9%A2%98%E6%98%AF%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%20JTAG%EF%BC%88%E9%80%9A%E8%BF%87%20J-Link%EF%BC%89%E5%88%9D%E5%A7%8B%E5%8C%96%20DDR%20%E5%B9%B6%E5%9C%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%20USB%20%E6%88%96%E5%86%85%E9%83%A8%E5%90%AF%E5%8A%A8%20ROM%20%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%EF%BC%88%E5%8D%B3%E7%BB%95%E8%BF%87%20UUU%20%E5%B7%A5%E5%85%B7%EF%BC%89%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%9C%A8%20RAM%20%E4%B8%AD%E5%8A%A0%E8%BD%BD%E5%92%8C%E6%89%A7%E8%A1%8C%E4%BB%A3%E7%A0%81%EF%BC%88%E4%BE%8B%E5%A6%82%20U-Boot%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%98%E6%98%AF%E5%BF%85%E9%A1%BB%E8%87%B3%E5%B0%91%E4%BD%BF%E7%94%A8%E4%B8%80%E6%AC%A1USB%20OTG%20%2B%20UUU%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E5%99%A8%E5%B0%86%E5%88%9D%E5%A7%8B%E4%BB%A3%E7%A0%81%E5%8A%A0%E8%BD%BD%E5%88%B0%E7%B3%BB%E7%BB%9F%E4%B8%AD%EF%BC%8C%E7%84%B6%E5%90%8E%E6%89%8D%E8%83%BD%E4%BB%8EeMMC%E5%90%AF%E5%8A%A8%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137507%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%94%AF%E6%8C%81%20Cortex-A53%20%E7%9A%84%20JTAG%20%E5%92%8C%20JLink%20%E8%84%9A%E6%9C%AC%EF%BC%8C%E5%BB%BA%E8%AE%AE%E7%9B%B4%E6%8E%A5%E5%BA%94%E7%94%A8%E4%BA%8E%20segger%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fforum.segger.com%2Findex.php%2FThread%2F4447-SOLVED-Cortex-A53-support%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fforum.segger.com%2Findex.php%2FThread%2F4447-SOLVED-Cortex-A53-support%2F%3C%2FA%3E%3CBR%20%2F%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E5%B0%86%20Lauterbach%20Trace32%20%E7%94%A8%E4%BD%9C%20Cortex-A53%20%E5%86%85%E6%A0%B8%E7%9A%84%E8%B0%83%E8%AF%95%E5%99%A8%E5%B7%A5%E5%85%B7%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137090%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%82%E8%80%83%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%20SDK%20%E5%92%8C%E5%B7%A5%E5%85%B7%E9%93%BE%E8%A1%A5%E4%B8%81%E9%93%BE%E6%8E%A5%E4%BB%A5%E5%8F%8A%E6%82%A8%E6%8F%90%E5%88%B0%E7%9A%84%20OpenOCD%20%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%E4%B8%80%E4%B8%AA%E6%B8%85%E6%99%B0%E5%AE%8C%E6%95%B4%E7%9A%84%E7%A4%BA%E4%BE%8B%E6%88%96%E6%8C%87%E5%8D%97%E6%9D%A5%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%3E%20%20%20%20%20%20*%20%E5%9C%A8%20i.MX8MQ%20(Cortex-A53)%20%E4%B8%8A%E9%80%9A%E8%BF%87%20JTAG%20%E5%88%9D%E5%A7%8B%E5%8C%96%20DDR%E3%80%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E*%20%E9%80%9A%E8%BF%87%20JTAG%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BD%BF%E7%94%A8%20SEGGER%20J-Link%EF%BC%89%E5%B0%86%20U-%E5%90%AF%E5%8A%A8%20%E6%88%96%E4%BB%BB%E4%BD%95%E8%87%AA%E5%AE%9A%E4%B9%89%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9B%B4%E6%8E%A5%E5%8A%A0%E8%BD%BD%E5%B9%B6%E6%89%A7%E8%A1%8C%E5%88%B0%20A53%20RAM%20%E4%B8%AD%EF%BC%8C%3C%2FP%3E%3CP%3E*%20%E5%AE%8C%E5%85%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E5%90%AF%E5%8A%A8%20ROM%20%E6%9C%BA%E5%88%B6%EF%BC%88%E5%8D%B3%E4%B8%8D%E4%BD%BF%E7%94%A8%20USB%2F%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E5%99%A8%E6%A8%A1%E5%BC%8F%EF%BC%89%E5%8D%B3%E5%8F%AF%E6%89%A7%E8%A1%8C%E6%AD%A4%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E6%9C%89%E7%9A%84%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%96%87%E7%8C%AE%E4%BC%BC%E4%B9%8E%E9%83%BD%E6%98%AF%3C%2FP%3E%3CP%3E%20%20%20%20%20*%20%E4%BB%A5%20Cortex-M4%20%E5%86%85%E6%A0%B8%E4%B8%BA%E7%9B%AE%E6%A0%87%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20*%20%E5%81%87%E8%AE%BE%E5%B7%B2%E5%AD%98%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E6%88%96%3C%2FP%3E%3CP%3E*%20%E4%B8%8E%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E5%8F%82%E8%80%83%E4%B8%80%E6%A0%B7%EF%BC%8C%E6%BC%94%E7%A4%BA%E5%8F%AA%E6%9C%89%E5%9C%A8%E9%80%9A%E8%BF%87%20USB%20%E5%92%8C%20UUU%20%E5%B7%A5%E5%85%B7%E5%8A%A0%E8%BD%BD%20U-Boot%20%E5%92%8C%E5%86%85%E6%A0%B8%E4%B9%8B%E5%90%8E%E6%89%8D%E8%83%BD%E9%80%9A%E8%BF%87%20JTAG%20%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E8%B0%83%E8%AF%95%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%9C%A8%E7%A9%BA%E7%99%BD%E8%AE%BE%E5%A4%87%E4%B8%8A%E8%BF%9B%E8%A1%8C%E5%85%A8%E9%9D%A2%E5%90%AF%E5%8A%A8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%90%A6%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%E5%AE%98%E6%96%B9%E6%98%AF%E5%90%A6%E6%94%AF%E6%8C%81%E9%80%9A%E8%BF%87%20JTAG%EF%BC%88%E4%B8%8D%E5%B8%A6%20USB%EF%BC%89%E5%90%AF%E5%8A%A8%20Cortex-A53%20%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E4%BD%A0%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E7%9B%B4%E6%8E%A5%E7%9A%84%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0%E3%80%81%E5%BA%94%E7%94%A8%E6%8C%87%E5%8D%97%E6%88%96%E7%A4%BA%E4%BE%8B%E8%84%9A%E6%9C%AC%EF%BC%88J-Link%E3%80%81Lauterbach%E3%80%81DS-5%20%E6%88%96%20OpenOCD%EF%BC%89%3C%2FP%3E%3CP%3E%20%20%20%20%20%20*%20%E6%88%96%E6%9C%89%E5%85%B3%20DDR%20%E8%AE%AD%E7%BB%83%E3%80%81%E4%BB%A3%E7%A0%81%E4%B8%8A%E4%BC%A0%E5%92%8C%E9%80%9A%E8%BF%87%20JTAG%20%E5%90%AF%E5%8A%A8%20A53%20%E7%9A%84%E4%BB%BB%E4%BD%95%E6%AD%A5%E9%AA%A4%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%BF%99%E5%AF%B9%E8%B0%83%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E5%AE%9A%E5%88%B6%E7%A1%AC%E4%BB%B6%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%88%91%E4%BB%AC%E7%9A%84%E5%AE%9A%E5%88%B6%E7%A1%AC%E4%BB%B6%E7%9B%AE%E5%89%8D%E6%B2%A1%E6%9C%89%E9%A2%84%E5%88%B7%E6%96%B0%E7%9A%84%E5%90%AF%E5%8A%A8%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%B9%9F%E6%B2%A1%E6%9C%89%20USB%20%E8%AE%BF%E9%97%AE%E6%9D%83%E9%99%90%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E5%8F%AF%E6%9C%9B%3C%2FP%3E%0A%3CP%3EIDE-%E8%B0%83%E8%AF%95%E3%80%81%E7%BC%96%E8%AF%91%E5%92%8C%E7%89%88%E6%9C%AC%E5%B7%A5%E5%85%B7%20(2)%20%3CBR%20%2F%3E%20SDK_2.3_mx8mq_beta_Patch%20(REV)sdk2.3_mx8mq_beta)%3CBR%20%2F%3E%EF%BC%88%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8F%90%E4%BE%9B%E4%BA%86%20IAR%20%E5%92%8C%20Segger%20%E5%B7%A5%E5%85%B7%E8%A1%A5%E4%B8%81%E4%BB%A5%E6%94%AF%E6%8C%81%20i.mx8MQuad%20%E8%AE%BE%E5%A4%87%EF%BC%89%3C%2FP%3E%0A%3CP%3E%3CA%20class%3D%22link-titled%22%20title%3D%22https%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fi.mx-developer-resources%2Fevaluation-kit-for-the-i.mx-8m-applications-processor%3AMCIMX8M-EVK%3Ftab%3DDesign_Tools_Tab%22%20href%3D%22https%3A%2F%2Ftranslate.google.com%2Fwebsite%3Fsl%3Den%26amp%3Btl%3Des%26amp%3Bhl%3Des%26amp%3Bclient%3Dsrp%26amp%3Bu%3Dhttps%3A%2F%2Fwww.nxp.com%2Fsupport%2Fdeveloper-resources%2Frun-time-software%2Fi.mx-developer-resources%2Fevaluation-kit-for-the-i.mx-8m-applications-processor%3AMCIMX8M-EVK%3Ftab%253DDesign_Tools_Tab%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ei.MX%208M%20%E8%AF%84%E4%BC%B0%E5%A5%97%E4%BB%B6%7CNXP%3C%2FA%3E%20%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%94%AF%E6%8C%81%20A53%20%E7%9A%84%20Lauterbach%20%E5%92%8C%20ARM%20DS-5%EF%BC%8C%E5%AF%B9%E4%BA%8E%20OpenOCD%EF%BC%8C%E5%8F%AF%E4%BB%A5%E7%9C%8B%E7%9C%8B%20a53%20%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%0A%3CP%3E%3CA%20class%3D%22link-titled%22%20title%3D%22http%3A%2F%2Ffatalfeel.blogspot.com%2F2015%2F12%2Fopenocd-with-eclipse-debug-kernel-of.html%22%20href%3D%22https%3A%2F%2Ftranslate.google.com%2Fwebsite%3Fsl%3Den%26amp%3Btl%3Des%26amp%3Bhl%3Des%26amp%3Bclient%3Dsrp%26amp%3Bu%3Dhttp%3A%2F%2Ffatalfeel.blogspot.com%2F2015%2F12%2Fopenocd-with-eclipse-debug-kernel-of.html%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E7%BC%96%E7%A8%8B%E6%8C%87%E5%8D%97%EF%BC%9AOpenOCD%20%2B%20Eclipse%20%2B%20Jtag%20%E5%9C%A8%20Uboot%20%E4%B8%8A%E8%B0%83%E8%AF%95%26amp%3B%20Linux%3C%2FA%3E%20%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2132594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2132594%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E9%80%9A%E8%BF%87%20JTAG%20%E5%9C%A8%20M4%20%E5%86%85%E6%A0%B8%E4%B8%8A%E5%8A%A0%E8%BD%BD%E5%9B%BA%E4%BB%B6%E7%9A%84%E7%9B%B8%E5%85%B3%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E6%89%BE%E5%88%B0%20Cortex-A53%20%E5%86%85%E6%A0%B8%E7%9A%84%E7%B1%BB%E4%BC%BC%E6%96%87%E6%A1%A3%E3%80%82%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E6%88%96%E5%90%91%E6%88%91%E6%8F%90%E4%BE%9B%E6%9C%89%E5%85%B3%E4%BD%BF%E7%94%A8%20JTAG%EF%BC%88%E5%A6%82%E4%BD%BF%E7%94%A8%E4%B8%96%E7%BA%AA%E4%BD%B3%E7%BC%98%20J-Link%EF%BC%89%E5%9C%A8%20Cortex-A53%20%E5%86%85%E6%A0%B8%EF%BC%88i.MX8MQ%EF%BC%89%E4%B8%8A%E5%8A%A0%E8%BD%BD%E5%92%8C%E8%BF%90%E8%A1%8C%E4%BB%A3%E7%A0%81%E7%9A%84%E5%AE%98%E6%96%B9%E6%96%87%E6%A1%A3%E6%88%96%E8%B5%84%E6%BA%90%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2130999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20i.MX8MQ%20%E2%80%93%20Initial%20code%20loading%20without%20USB%2FUUU%20using%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130999%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20jtag%20%E6%88%96%E5%8D%95%E7%8B%AC%E5%AF%B9%20eMMC%20%E6%88%96%20SD%20%E5%8D%A1%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E9%97%AE%E5%80%99%3C%2FP%3E%3C%2FLINGO-BODY%3E
