i.MX8MM - No Audio Data on SAI3 when capturing
martintownsend
We have an SGTL5000 connected to SAI3 where the SAI3 is the I2S Master.  We've modified the imx-sgtl5000 machine driver to cater for this and set it so that it doesn't support just playback. We've also modified the driver to remove all the audmux stuff as the i.MX8 MM doesn't have one.  We've ensure all the drivers required are enabled in the kernel.
We're connected the codec in the same manner that the WM8524 is connected on the EVK with the exception that we are really interested in Audio capture so we have
I2S_DIN -> SAI3_TXD
I2S_DOUT -> SAI3_RXD
I2S_SCLK -> SAI3_TXC
I2S_LRCLK -> SAI3_TXFS
I2S_MCLK -> SAI3_MCLK
The SAI is configured so that the transmitter is asynchronous but the receiver is synchronous, from the reference manual
"If the transmitter bit clock and frame sync are to be used by both the
transmitter and receiver:
• The transmitter must be configured for asynchronous operation and
the receiver for synchronous operation.
• In synchronous mode, the receiver is enabled only when both the
transmitter and receiver are enabled.
• It is recommended that the transmitter is the last enabled and the
first disabled."
But when recording we are getting silence.  I have put debug code in imx_pcm_dma_v2_complete and there is nothing in the memory that should be DMA'd to.  The RDR0 register is always zero as well.  If I write data into the memory that should have been DMA'ed it arrives in user space and arecord gets data.  So the problem is somewhere in the SAI.  We have probed all the signals and the clocks are all fine and SAI3_RXD is toggling indicating data is present and not just zeros so we believe codec is working fine.
I noticed in the driver the following in fsl_sai_trigger when it starts a capture
regmap_update_bits(sai->regmap, FSL_SAI_xCSR(tx, offset),
FSL_SAI_CSR_FRDE, FSL_SAI_CSR_FRDE);
FSL_SAI_CSR_TERE, FSL_SAI_CSR_TERE);
FSL_SAI_CSR_SE, FSL_SAI_CSR_SE);
According to the reference manual SW shouldn't be writing to bit 30 of the xCSR register but this line does for some reason. There isn't even a bit called SE in the document.  I've tried taking this out but it still doesn't work.
Here's a dump of the receive and transmit registers when Trigger start occurs
[ 4085.442364] TRIGGER START
[ 4085.444986] FSL_SAI_TCSR: 0x00000008: 0x90100000
[ 4085.449602] FSL_SAI_TCR1: 0x0000000c: 0x0000007a
[ 4085.454220] FSL_SAI_TCR2: 0x00000010: 0x07000007
[ 4085.458838] FSL_SAI_TCR3: 0x00000014: 0x00000000
[ 4085.463456] FSL_SAI_TCR4: 0x00000018: 0x00010f3b
[ 4085.468074] FSL_SAI_TCR5: 0x0000001c: 0x0f0f0f00
[ 4085.472693] FSL_SAI_RCSR: 0x00000088: 0x90100c01
[ 4085.477311] FSL_SAI_RCR1: 0x0000008c: 0x00000005
[ 4085.481928] FSL_SAI_RCR2: 0x00000090: 0x43000000
[ 4085.486546] FSL_SAI_RCR3: 0x00000094: 0x00010000
[ 4085.491164] FSL_SAI_RCR4: 0x00000098: 0x00010f3b
[ 4085.495780] FSL_SAI_RCR5: 0x0000009c: 0x0f0f0f00
I can't see anything obvious from reading the reference manual.  I'm really stuck now as to why we are getting no data being received from the codec when there is data on the RXD line.  Is there something wrong with the SAI configuration above?
uname -a returns:
Linux imx8mmevk 4.14.98-imx_4.14.98_2.0.0_ga+g5d6cbeafb80c #1 SMP PREEMPT Tue Sep 24 06:36:55 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux
Any help greatly appreciated,
Martin.
martintownsend
The problem in the end was down to the device tree.  I had put all the audio configuration in a dtsi and included it from the imx8mm evk dts but then forgot to remove the SAI3 node and pinmux from the evk dts which then overrode my sai3 and sai3 pinmux that I had setup which included the setup for the RXDATA pin (hence no data).
For anyone that arrives here as audio capture isn't working check the pinmux has been applied correctly by checking out
/sys/kernel/debug/pinctrl/
Cheers,
Martin.
martintownsend
An update.  If I configure the SAI3_RXD as a GPIO (GPIO4_IO30) and export to SYSFS I can see it toggle when a capture is in progress and 0 when it's not
oot@imx8mmevk:~# while true; do cat /sys/class/gpio/gpio126/value | tr -d '\n'; done
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000011000010010001010001000011011011001110000011110001011110000001011110011100010010001
[snip..]
0101010101000101011110011000000001001001000100001000010001011001001101110111110001001101101101011010001010101100101101100000000000000000000100011001001000100000110010000010000110000001010001100000100000001011000101000100010001000000001000000011011101000001001000000000000000101100101000000110000000000000001010001011000000000000000000111010101000000000010011011100001000001001111000010100100010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000^C
So this proves data is coming out of the DOUT pin of the codec and is reaching the the SAI3_RXD pin on the i.MX8MM.
I have modified the SAI driver to disable the DMA request and enable the FIFO request interrupt and in this interrupt read the RDR0 register until the RD == RW pointer in the RFR0 register.  The interrupt fires but I only read zeros out of the RDR0 register.  I don't understand why I'm not seeing the data in the Receiver FIFO if the Frame, Bit and MCLK are correct and data is appearing on the SAI3_RXD pin.
There must be some problem with the Receiver being synchronised to the Transmitter clocks.
Are we supposed to be wiring the RX_SYNC and RX_BCLK signals in some special way even though we aren't using them?
Many Thanks,
Martin.
Hi Martin
one can check below links which may be helpful
WM8960 with Nitrogen i.MX8M Mini board
linux-imx6/imx8mm-nitrogen8mm.dts at boundary-imx_4.14.x_2.0.0_ga · boundarydevices/linux-imx6 · Git...
TLV320AIC3111 with i.MX8M Mini EVK
SAI on i.MX8M Mini
DART-MX8M Audio record play - Variscite Wiki
