I'll be using TLV320AIC3106 codec from TI. How should I connect this codec with my i.mx8mp MPU, which peripheral should I connect and main clk of codec which is 12.28 MHz can be generated via mpu or do I need to use an oscillator?
Thank you in advance,
Best Regards.
Hi @Wobaffet,
I hope you are doing well.
One can refer to the i.MX8MP EVK BB schematic for Audio Codec connections.
Thanks & Regards,
Ritesh M Patel
