i.MX8M plus mmap() issue
1,860 次查看
Na-veen
Could it be possible to access DDR area from Linux user space with mmap() or related? I need a SHM- area between A53 process and am searching a minimum effort solution to realize that.
Nav
3 回复数
1,852 次查看
b36401
Do you mean to communicate between A and M cores?
You can use rpmsg for such purposes.
1,845 次查看
Na-veen
For communication between a53. I am trying to secure memory area between the cores.
Nav
1,858 次查看
Na-veen
Simple code example,
Trying to build simple application with below lines of code and it fails allocate memory with "No such device error"
char * region = mmap(NULL,4096, PROT_WRITE,MAP_PRIVATE,0,0);
