i.MX8M plus - MIPI CSI 2 supports packets with virtual channel ID
1,549 次查看
shai_b
Senior Contributor II
Dear Team,
My customer is planning to use two MT9M114 (from On-Semi) CMOS sensors and combine the two MIPI-CSI2 ports into one port (using Lattice FPGA device).
My question is, does i.MX8M Plus MIPI-csi2 interface knows to handle virtual channel ID and separate back the MIPI signal into two channels?
Waiting for your kind response, Thanks in advance
BR,
Shai
1,544 次查看
igorpadykov
Hi Shai
unfortunately i.MX8M Plus MIPI-CSI hardware does not support virtual channels, sorry.
1,074 次查看
M-tech
Dear Team,
Which of your processors does accept virtual channel for mipi-csi2 interface?
1,545 次查看
igorpadykov
Hi Shai
1,536 次查看
shai_b
@igorpadykov ,
Thank you for your feedback.
KR,
Shai
