i.MX8M Plus Pin atributes (Different IOMUX Selections)
Charlie_Owz
Hi!
I have seen tables with the different IOMUX possible selections but not for iM8M Plus.
Is it available somewhere?
On reference manual is all the data but I cannot find it summed up in a table similiar to this:
Many thanks in advance!
Charlie_Owz
Thanks for your answer.
Yes! We use that tool, and thank to you we are now with the latest v10.
We want that table to make easy to some workmates that can not use the tool to have all the info summed up and visually accesible. We know also that the info is in the reference manual, but with that table in a glance, you can see what ALT mode is, the reset value, the other pin mux options... etc.
Yes, we have the information located (PinMux Tool and Reference Manual), but we would like to know if there is this table that we have seen with other microprocessor for the iMX8M Plus.
Thanks! And have a nice week.
weidong_sun
Why not use " Config Tools for i.MX Applications Processors "?
It is specially designed for hardware engineer to IOMUX and assgn CPU pins for his application.
Download and install it to your computer, please!
https://www.nxp.com/design/designs/config-tools-for-i-mx-applications-processors:CONFIG-TOOLS-IMX
Have a good day!
weidong
