i.MX8M Plus NVCC_SD2 on Schematic
Wobaffet
Senior Contributor I
Should we connect the NVCC_SD2 pin of the i.MX8M Plus to VDD_1V8 for our custom board? We don't have an sd card on sd2 but we use that part as a GPIO. Thank you in advance!
Best Regards.
riteshmpatel
Hi @Wobaffet,
I hope you are doing well.
Since the uSDHC2 interface pins are used as GPIOs and NVCC_SD2 is the reference power rail for the uSDHC2 interface, one needs to connect NVCC_SD2 to the desired voltage level.
Thanks & Regards,
Ritesh M Patel
riteshmpatel
Hi @Wobaffet,
Thanks & Regards,
Ritesh M Patel
