i.MX8M Plus ISP: Autofocus not working
Search instead for
rhubert
I added a new Sensor to the isp-imx package in `units/isi/drv/AR0521/source` based on the existing OV2775 driver. ATM I'm also using the calibration file from this sensor.
For unknown reasons the Autofocus callbacks
pIsiSensor->pIsiFocusSetupIss
pIsiSensor->pIsiFocusReleaseIss
pIsiSensor->pIsiFocusSetIss pIsiSensor->pIsiFocusGetIss pIsiSensor->pIsiGetFocusCalibrateIss
 called. What do I need to do to enable this feature?
Ralf
Tags (2)
artsiomstaliaro
isp-imx-4.2.2.18.0 has already autofocus examples.
artsiomstaliaro
Autofocus is normally disabled in default calibration files. You need to ask NXP FAE to give you the right settings.
https://www.nxp.com/support/support/nxp-engineering-services/professional-support-for-processors-and...
