i.MX8M Plus: How to use SPDS to download data to memory address
1,222 次查看
jlok
At i.MX8MQ, we used SDP to download data (~2K bytes) to a memory address.
e.g.
uuu sdp: write -f data.bin -addr 0x184000
However, i.MX8M Plus changed to SDPS. How to use SDPS to download data to a memory address 0x184000.
1,200 次查看
jlok
The main purpose is to load the DDRC setting without rebuilding the uboot.bin file. Just download the data to memory and use it at bootup.
1,188 次查看
Zhiming_Liu
If you want to debug uboot.bin, you need get relocate address from uboot using command "bdinfo",then use uuu download it to ram relocate address.
Zhiming
