Thank you for the clarification.
I understand that this DDR4 guideline document applies to Layerscape and QorIQ devices,
and that for i.MX parts we should follow i.MX-specific board layout guideline documents.
However, for the i.MX 8M Plus (MIMX8ML8CVNKZAB), we could not find a document that provides
sufficient and concrete DDR4 layout guidance, such as:
- Explicit DDR4 pin / byte / nibble swapping rules
- Detailed routing constraints for DDR4 (length matching, impedance, topology, etc.)
- Any reference designs or layout examples using DDR4 with i.MX 8M Plus
The i.MX8MP Hardware Development Guide and Reference Manual mention DDR4 support,
but do not clearly describe the allowable pin-swapping rules or detailed PCB layout constraints.
Could you please advise:
- Which specific NXP document should be considered authoritative for DDR4 layout on i.MX 8M Plus?
- Or whether it is acceptable to refer to AN5097 (DDR4 Design Checklist) as a guideline,
even though it is not explicitly stated to apply to i.MX 8M Plus?
Any clarification would be greatly appreciated.
