Hi @Sanket_Parekh,
I don't know if this is the proper medium to share all details and have back and forth comm. Though, I am working with Ryan, Venkat and Greg on this issue. So it would be great if team internally can collaborate on this issue to get to the speed.
Please note that, for many days, this portal service was completely non-functional.
Answers are inline.
1. Does it have the same problem when using combo firmware?
Ans: We don't use combo firmware at all as it's not our use case. So we don't have data analysis on combo firmware.
2. Does it have the same problem when using on board 88W8987 module or other modules?
Ans: We don't have 88W8987 module on board as it's not our use case. So we don't have data analysis on 88W8987 module.
Not sure, why you're not able to see any files that I attached to the ticket, but everything is there. So sorry probably contact NXP support portal team for that issue as I have no idea, how can I make that available from my end. Or if you'll contact people that I mentioned above, then the team will be able to get to the speed much faster anyway.
Thank you for all help!
Dhruv
