i.MX8M Mini dual core processor unused pins terminations
956件の閲覧回数
nija_mankodi
Hi Team,
We are developing a product base don 8M Mini dual core processor MIMX8MM4CVTKZAA.
I have attached an xls in which all the unused pins (As per our design) are mentioned. There is no information in datasheet/guideline document on how to terminate these pins if not used.
Could you please help to confirm recommended terminations (NC or GND) against each unused pins mentioned in xls?
3 返答(返信)
930件の閲覧回数
Hi nija_mankodi
unused digital signals can be configured as gpios inputs with enabled pull-ups,
for analog one can look at sect.3.9. Unused input/output terminations
i.MX 8M Mini Hardware Developer’s Guide
925件の閲覧回数
nija_mankodi
Noted.
Does this mean that we can leave these unused digital pins floating (not connected)?
919件の閲覧回数
yes
