i.MX8M Mini VPU Registers
sachin_patel
I noticed in the i.MX8M Mini Reference Manual, Chapter 15, VPU_H1, Register SWREG441 has the same description as SWREG440. Is this a mistake in the documentation?
Kind regards,
Sachin Patel
Zhiming_Liu
Hi sachinpatel
Yes, it is a mistake.It should a high 32 and a low 32.
Best Regards
Zhiming
sachin_patel
Hi @Zhiming_Liu
Are you sure that's the case? That does not follow the pattern in the neighbouring registers. The "low 32-bit" registers appear much earlier in the mapping as I expect the value in the "high 32-bit" registers are zero. Notice that all registers from SWREG429 - SWREG449 are all labelled as "High 32-bit", and the preceding registers SWREG423 - SWREG428 are all labelled as "Base Address MSB".
Sach
