i.MX8M Mini L2 cache access
1,006 次查看
m_c
Senior Contributor I
Is it possible to acess L2 cache in bare metal mode (jailhouse inmate)? If not, which memory has fastest access time that bare matel mode can access?
868 次查看
igorpadykov
Hi m.c.
seems not as discussed on arm forum:
Using the whole Cortex-A L2 Cache without external memory - Cortex-A / A-Profile forum - Processors ...
DDR memory would be fastest access as it is designed for such purpose.
869 次查看
igorpadykov
Hi m.c.
