I am looking to use an i.MX 8M Plus with an image coprocessor. The coprocessor I am using communicates over sub-LVDS MIPI. I am wondering if this signal level is compatible with the MIPI CSI PHY on the i.MX 8M Plus.
It is my understanding that a sub-LVDS driver can drive an LVDS receiver, so since the MIPI CSI interface on the i.MX 8M Plus is just receiving camera data, there should be no issue. Correct?
Solved! Go to Solution.
Yes you are correct!.
Thanks for the help!
