i.MX8M Change System mode(EL1) to User mode(EL0)
Hariharan1
Hi Experts,
I have been successfully routing el3 to el1. but i am not able to change EL1 to EL0 in uboot code(Branch - imx_v2019.04_4.19.35_1.1.0). what can be an issue. This code, i have inserted in uboot.
ESR_EL1 value is 0x92000210
Data Abort exception from a lower Exception level.
Used for MMU faults generated by data accesses, alignment faults other than those
caused by Stack Pointer misalignment
el1_to_el0:
                  ADR x0, User_level_function
                  MSR ELR_EL1, x0 // Set return address in EL0
                  MOV x1, #0
                  MSR SPSR_EL1, x1
                  mov x2, sp
                  MSR SP_EL0, x2
                  ERET // Return to EL0
Bio_TICFSL
