i.MX8DualX+ Power Up Timing
Search instead for
jbrayadec
Section 4.2.1 "Power-up Sequence" lists the order in which the i.MX8Quad/DualX power supplies need to come up for proper operation.  It says that each power group can power up in sequence or "simultaneously" with the other groups.  How close to hitting their nominal voltage do they need to be to be considered "simultaneous"?
Jeff
jbrayadec
Thanks for the reply, but maybe my question wasn't clear enough.  I'm looking for the timing of the power supplies coming up to their nominal voltages as listed in Table 9.  For example, if they all come up and are stable with 1us of each other is that suitable?  What about 5us?  10us?
Jeff
if they are stable with 0us of each other (immediately) it is suitable.
Hi jbrayadec
regarding "How close to hitting their nominal voltage", voltage should be within
range specified Table 9. Operating ranges
i.MX 8DualX Industrial Applications Processors - Data Sheet
Also sect.4.2.1 has Note:
The definition of “power-up” refers to a stable voltage operating within the
range defined in Table 9.
