i.MX8 ULP EVK - core-image-minimal-secure-boot build problem
2,198件の閲覧回数
ddresser
I am trying to build a minimal secure boot exmple for an i.MX8 ULP EVK board using these commands
# repo init -uhttps://github.com/nxp-imx/imx-manifest -b imx-linux-scarthgap -m imx-6.6.23-2.0.0_security-reference-design.xml
# DISTRO=fsl-imx-wayland MACHINE=imx8ulp-lpddr4-evk source imx-setup-release.sh -b buil
echo "CST_PATH = \"/my/path/to/cst-3.4.1\"" >> conf/local.conf
# bitbake core-image-minimal-secure-boo
I have generated the certs and keys with CST.
I am seeing this error:
ERROR: cargo-native-1.75.0-r0 do_compile: ExecutionError('/home/ddresser/src/imx-yocto-bsp-secureboot/build/tmp/work/x86_64-linux/cargo-native/1.75.0/temp/run.do_compile.19360', 101, None, None)
ERROR: Logfile of failure stored in: /home/ddresser/src/imx-yocto-bsp-secureboot/build/tmp/work/x86_64-linux/cargo-native/1.75.0/temp/log.do_compile.19360
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: Using rust targets from /home/ddresser/src/imx-yocto-bsp-secureboot/build/tmp/work/x86_64-linux/cargo-native/1.75.0/rust-targets/
| NOTE: cargo = /home/ddresser/src/imx-yocto-bsp-secureboot/build/tmp/work/x86_64-linux/cargo-native/1.75.0/cargo-1.74.0-x86_64-unknown-linux-gnu/bin/cargo
| NOTE: /home/ddresser/src/imx-yocto-bsp-secureboot/build/tmp/work/x86_64-linux/cargo-native/1.75.0/cargo-1.74.0-x86_64-unknown-linux-gnu/bin/cargo build -v --frozen --target x86_64-unknown-linux-gnu --release --manifest-path=/home/ddresser/src/imx-yocto-bsp-secureboot/build/tmp/work/x86_64-linux/cargo-native/1.75.0/rustc-1.75.0-src/src/tools/cargo//Cargo.toml
| error: could not execute process `rustc -vV` (never executed)
| Caused by:
|  Exec format error (os error
| WARNING: exit code 101 from a shell command.
ERROR: Task (virtual:native:/home/ddresser/src/imx-yocto-bsp-secureboot/sources/poky/meta/recipes-devtools/rust/cargo_1.75.0.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2232 tasks of which 2231 didn't need to be rerun and 1 failed.Summary: 1 task failed:
I have tried cleaning and rebuilding cargo-native and rust with the same results. Any suggestions are appreciated. Thanks.
2,142件の閲覧回数
ddresser
I resolved this by updating the repo manifest.  I submitted a pull request with a fix.
https://github.com/nxp-https://github.com/nxp-imx/imx-manifest/pull/8/imx-manifest/pull/8
5 返答(返信)
2,143件の閲覧回数
ddresser
2,131件の閲覧回数
Harvey021
Thanks for the note, will inform the owner to have an update.
You can also work with other BSP - like the one for reference - L6.6.36_2.1.0-DOCS
Harvey
Harvey
2,165件の閲覧回数
ddresser
FYI, running the command as it appears in the doc gives this:
ddresser@elmore:~/src/imx-yocto-bsp-secureboot$ repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-scarthgap -m imx-6.6.52-2.2.0_security-reference-design.xml
Downloading Repo source from https://gerrit.googlesource.com/git-repo
fatal: manifest 'imx-6.6.52-2.2.0_security-reference-design.xml' not available
fatal: manifest imx-6.6.52-2.2.0_security-reference-design.xml not found
Repo command failed: UpdateManifestError
        Unable to sync manifest imx-6.6.52-2.2.0_security-reference-design.xml
2,165件の閲覧回数
ddresser
Thanks for the response.  Yes, I have tried that.
I am using the process:
10.9.1.3 Yocto setup for secure boot build
from https://www.nxp.com/docs/en/user-guide/IMX_LINUX_USERS_GUIDE.pdf
I am able to build the non-secure boot process from the same document successfully.
I just noticed that the document specifies the `imx-6.6.52-2.2.0_security-reference-design.xml` on the `imx-linux-scarthgap` branch
repo init -u https://github.com/nxp-imx/imx-manifest -b imx-linux-scarthgap - m imx-6.6.52-2.2.0_security-reference-design.xml
However, that branch has this version of the file:
imx-6.6.23-2.0.0_security-reference-design.xml`
I see references to the 6.6.52 version in the commit notes, but don't see that file.
2,178件の閲覧回数
Harvey021
Have you tried to bitbake -c cleanll cargo; bitbake cargo?
And assume that your host to build is version of Ubuntu 22.04 and all packages for host setup not missed.
Harvey
%3CLINGO-SUB%20id%3D%22lingo-sub-2031862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX8%20ULP%20EVK%20-%20core-image-minimal-secure-boot%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2031862%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81i.MX8%20ULP%20EVK%E3%83%9C%E3%83%BC%E3%83%89%E7%94%A8%E3%81%AE%E6%9C%80%E5%B0%8F%E9%99%90%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E4%BE%8B%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%23%20%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20init%20-u%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%20nofollow%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%3C%2FA%3E-b%20imx-linux-scarthgap%20-m%20imx-6.6.23-2.0.0_security-reference-design.xml%3CBR%20%2F%3E%23%20DISTRO%3Dfsl-imx-wayland%20MACHINE%3Dimx8ulp-lpddr4-evk%20source%20imx-setup-release.sh%20-b%20buil%3CBR%20%2F%3Eecho%20%22CST_PATH%20%3D%20%5C%22%2Fmy%2Fpath%2Fto%2Fcst-3.4.1%5C%22%22%20%26gt%3B%26gt%3B%20conf%2Flocal.conf%3CBR%20%2F%3E%23%20bitbake%20core-image-minimal-secure-boo%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ECST%E3%81%A7%E8%A8%BC%E6%98%8E%E6%9B%B8%E3%81%A8%E3%82%AD%E3%83%BC%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSTRONG%3E%3Acargo-native-1.75.0-r0%20do_compile%3AExecutionError('%2Fhome%2Fddresser%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fcargo-native%2F1.75.0%2Ftemp%2Frun.do_compile.19360'%2C101%E3%80%81%E3%81%AA%E3%81%97%E3%80%81%E3%81%AA%E3%81%97)%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSTRONG%3E%3A%E9%9A%9C%E5%AE%B3%E3%81%AE%E3%83%AD%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%2F%20home%20%2F%20ddresser%20%2F%20src%20%2F%20imx-yocto-bsp-secureboot%20%2F%20build%20%2F%20tmp%20%2F%20work%20%2F%20x86_64-linux%20%2F%20cargo-native%20%2F%201.75.0%20%2F%20temp%20%2F%20log.do_compile.19360%3CBR%20%2F%3E%E3%83%AD%E3%82%B0%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%7CDEBUG%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%E9%96%A2%E6%95%B0%20do_compile%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%7C%E6%B3%A8%3A%2Fhome%2Fddresser%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fcargo-native%2F1.75.0%2Frust-targets%2F%E3%81%AERust%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E%7C%E6%B3%A8%3Acargo%20%3D%20%2Fhome%2Fddresser%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fcargo-native%2F1.75.0%2Fcargo-1.74.0-x86_64-unknown-linux-gnu%2Fbin%2Fcargo%3CBR%20%2F%3E%7C%E6%B3%A8%3A%20%2Fhome%2Fddresser%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fcargo-native%2F1.75.0%2Fcargo-1.74.0-x86_64-unknown-linux-gnu%2Fbin%2Fcargo%20build%20-v%20--frozen%20--target%20x86_64-unknown-linux-gnu%20--release%20--manifest-path%3D%2Fhome%2Fddresser%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fbuild%2Ftmp%2Fwork%2Fx86_64-linux%2Fcargo-native%2F1.75.0%2Frustc-1.75.0-src%2Ftools%2Fcargo%2F%2Fcargo.toml%3CBR%20%2F%3E%7C%E3%82%A8%E3%83%A9%E3%83%BC%3A%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%20'rustc%20-vV'%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F(%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F)%3CBR%20%2F%3E%7C%3CBR%20%2F%3E%7C%E5%8E%9F%E5%9B%A0%3A%3CBR%20%2F%3E%7C%20Exec%20%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%20(os%20%E3%82%A8%E3%83%A9%E3%83%BC%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%7C%E8%AD%A6%E5%91%8A%3A%20%E3%82%B7%E3%82%A7%E3%83%AB%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8B%E3%82%89%E3%82%B3%E3%83%BC%E3%83%89%20101%20%E3%82%92%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CSTRONG%3E%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FSTRONG%3E%3A%E3%82%BF%E3%82%B9%E3%82%AF(virtual%3Anative%3A%2Fhome%2Fddresser%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Frust%2Fcargo_1.75.0.bb%3Ado_compile)%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%89%E3%80%8C1%E3%80%8D%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CSTRONG%3E%E6%B3%A8%3C%2FSTRONG%3E%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%AE%E6%A6%82%E8%A6%81%3A%202232%20%E5%80%8B%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%82%92%E8%A9%A6%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%81%86%E3%81%A1%202231%20%E5%80%8B%E3%81%AF%E5%86%8D%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%AA%E3%81%8F%E3%80%811%20%E5%80%8B%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%A6%82%E8%A6%81%3A%201%20%E3%81%A4%E3%81%AE%E3%82%BF%E3%82%B9%E3%82%AF%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3Evirtual%3Anative%3A%2Fhome%2Fddresser%2Fsrc%2Fimx-yocto-bsp-secureboot%2Fsources%2Fpoky%2Fmeta%2Frecipes-devtools%2Frust%2Fcargo_1.75.0.bb%3Ado_compile%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%82%AB%E3%83%BC%E3%82%B4%E3%83%8D%E3%82%A4%E3%83%86%E3%82%A3%E3%83%96%E3%81%A8%E9%8C%86%E3%81%B3%E3%81%9F%E6%8E%83%E9%99%A4%E3%81%A8%E5%86%8D%E6%A7%8B%E7%AF%89%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E7%B5%90%E6%9E%9C%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%82%93%E3%81%AA%E6%8F%90%E6%A1%88%E3%82%82%E5%A4%A7%E6%AD%93%E8%BF%8E%E3%81%A7%E3%81%99%E3%80%82%E6%84%9F%E8%AC%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2032685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%20ULP%20EVK%20-%20core-image-minimal-secure-boot%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2032685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%83%9E%E3%83%8B%E3%83%95%E3%82%A7%E3%82%B9%E3%83%88%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%93%E3%82%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%BF%AE%E6%AD%A3%E3%82%92%E5%8A%A0%E3%81%88%E3%81%9F%E3%83%97%E3%83%AB%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%82%92%E6%8F%90%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%2Fpull%2F8%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%2Fpull%2F8%2Fimx-manifest%2Fpull%2F8%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2032464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20i.MX8%20ULP%20EVK%20-%20core-image-minimal-secure-boot%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2032464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%AF%E3%81%84%E3%80%81%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E10.9.1.3%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%83%93%E3%83%AB%E3%83%89%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AEYocto%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_LINUX_USERS_GUIDE.pdf%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FIMX_LINUX_USERS_GUIDE.pdf%3C%2FA%3E%20%E3%81%8B%E3%82%89%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%90%8C%E3%81%98%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8B%E3%82%89%E9%9D%9E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%96%E3%83%BC%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%A1%E3%82%87%E3%81%86%E3%81%A9%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%20'imx-linux-scarthgap'%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AE%20'%3CSTRONG%3Eimx-6.6.52-2.2.0_security-reference-design.xml%3C%2FSTRONG%3E'%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%20init%20-u%20%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fimx-manifest%3C%2FA%3E-b%20imx-linux-scarthgap%20-%20m%20imx-6.6.52-2.2.0_security-reference-design.xml%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%81%9D%E3%81%AE%E3%83%96%E3%83%A9%E3%83%B3%E3%83%81%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3Eimx-6.6.23-2.0.0%3C%2FSTRONG%3E_security-reference-design.xml'%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%9F%E3%83%83%E3%83%88%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AB%206.6.52%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
