i.MX8 QuadXPlus and 8QuadMax[Android 11.0.0_2.0.0 ] screen display is cropped
1,038件の閲覧回数
Nicy
Issue:
After flashing I.MX 8 board with prebuilt image screen visibility is partial [Cropped screen].
Please find the attached image for reference
Hardwares used :
i.MX 8QuadXPlus and 8QuadMax MEK Board.
Prebuilt image used:
Android 11.0.0_2.0.0 (Linux 5.10.9 kernel) from  Android OS for i.MX Applications Processors
Displays used:
  1. TV with resolution 1280x720[ Panasonic TV ]
    2. HDMI 10” display with ,1280×800 high resolution [10''Display]
After changing resolution in bootargs to  androidboot.displaymode=720p30 . TV screen could fit screen but 10” display became blank[ only back light of power is seen].
Please find the logs attached for 10” display.
We would like to bring up screen on 10” display in full screen[ Without cropping]. Please guide us on how to achieve it.
843件の閲覧回数
Nicy
Thanks for the update
We could launch projection on 1280* 800 , 30fps   by updating display mode from bootargs.
##setenv append_bootargs androidboot.displaymode=1200x8000p30
1,010件の閲覧回数
Zhiming_Liu
The prebuilt image can't support 1280x800.You need download the source code and add timing information in drivers/gpu/drm/imx/hdp/imx-hdp.c
