The NXP's MCIMX8QM-CPU, i.MX8 Multisensory Enablement Kit is using iMX8 QuadMax processor :
i.MX 8QuadMax/QuadPlus Multisensory Enablement Kit | NXP
Is there an Eval board available using iMX8 QuadPlus processor instead?
cheers,
Selcuk
Solved! Go to Solution.
Hello Selcuk,
There is not a MEK board with the i.MX8QuadPlus populated. However, you may use the i.MX8QuadMax MEK as evaluation board when designing for the i.MX8QuadPlus as these processors are pin to pin compatible.
For reference, you may consult the i.MX8QM/i.MX8QP Hardware Design Guide (link below, please note that you may need to login to download this document), where you may see that there are very few differences on the design with these two processors.
https://www.nxp.com/webapp/Download?colCode=IMX8HWDG
My apologies for the inconvenience. I hope this helps!
Hello Selcuk,
