i.MX8 Quad Max impedance of PCIE and SATA
Search instead for
Senior Contributor I
For i.MX8 Quad Max there is only one pin for setting the impedance of PCIE and SATA: PCIE_REXT
As SATA and PCIE using different differential impedance i think there is no "optimum" for the impedance.
What is the recommendation for PCIE_REXT when using two PCIE-Lanes and one SATA.?
Can we use 85 Ohm for driver but routing with 100 Ohm from SATA specification?
Hi Martin
preliminary document with routing recommendations was sent via mail.
Community Manager
This an automatic process.
We are marking this post as solved, due to the either low activity or any reply marked as correct.
If you have additional questions, please create a new post and reference to this closed post.
NXP Community!
Hi Martin
Thanks igor, I answered your email, as it wasnt helpful at the moment.
Hi Martin
this part is not officially released yet and not supported. Suggest to
apply to nxp local marketing office for additional support.
For the case of PCIe plus SATA use 85-ohm value, BSP SATA driver adjusts PHY register to compensate.
Ross
